TS1 Modular Shelving (with CNC Wood Threading)
25,499
239
9
About: I am a designer/maker based in Utrecht, The Netherlands.
TS1 is modular shelving unit, relying on threaded wooden rods made with a CNC router. It’s my latest design & I’d like to share how I made it. More info on the finished product on my website.
Although it can be done with a hobby grade CNC (like the x-carve) it does require some special tools and possibly small modifications in the CNC bed (like drilling a big hole).
Supplies:
Step 1: Materials
Materials you'll need:
  • A sheet of 2440mm x 1220 mm 18 mm (4’ x 8’x ¾”) Plywood (or any plate material for that matter)
  • 38mm (1 ½ “) square or round stock, hardwood of your choice (I used birch)
For the sake of making this instructable shorter I won’t cover how to make round stock from a rough board. Internet is full of those. Here’s one way to do it: https://www.instructables.com/id/Making-Dowel-Rod...
Step 2: Tools
Tools you'll need
  • CNC router (x-carve in my case)
  • End mill - cutting radius 10 mm (25/64”), flute length - 45mm (~1.8”)
  • Thread mill - cutting radius 19mm (¾”), flute length - 50mm (~2”)
    I purchased mine from here: https://www.keocutters.com/product/72800/
  • Basic woodworking tools (tablesaw, drill, drill bits, hand-sander, jigsaw)
Step 3: CNC Files
I’m sharing the g-code files exported from Fusion 360, meant to be used with easel on the x-carve. However I’m also sharing the Fusion 360 models, so you can easily export it to other formats (I think?)
Step 4: Preparing the CNC for Clamping of Long Round Stock
If your CNC setup is similar to ours it will require drilling into the bed (I’ve drilled it on the far left corner), make the hole slightly larger than the rod itself - 30mm (1 3/16”).
Here’s my solution of how to clamp down the wooden rods. A simple clamp made from plywood, that’s mounted in existing holes on the x-carve bed with 4 bolts. The camping mechanism itself is dead simple, just a few bolts and half round plates that clamp around the rods.
Step 5: Machining the Threads
Cut the round stock to final lengths. If you’re building following my example precisely you’ll need:
  • 20 pcs - 355mm (14“)
  • 4 pcs - 100mm (3.9“)
  • 4 pcs - 140mm (5.5“)
There are two steps on each piece being threaded. First step is preparing the tenon (or mortise) with a flat end mill. Second step is machining the thread with that special bit.
I’ve shared two pairs of files, each pair is meant for its respecting thread. One for the outside thread & one for the inside thread (be extra careful to not mix these up, speaking from experience...)
The files provided have a starting point at the top-center of the stock. Make sure to align it perfectly when you home your CNC, you only need to do it once.
Make sure the rods are sticking out enough above the bed (the tenon is ~40mm (1 ⅔ ”) in height).
Step 6: The Shelves
This part is pretty straight forward. Again, if you want to copy the example I made you’ll need:
  • 6 pcs of 18mm (¾”) pine plywood (good quality) - 310mm x 1000mm (12.2” x 39.4”)
Once the parts are cut out mark the locations of the four holes on each plate. Mark the round corner from center of each hole with a compass.
Drill the holes just a bit bigger diameter than the tenon, in this case I drilled 28mm (1.1”) holes, as the tenon is 26mm (1.02” ). That gives you some tolerance in case the holes are not marked dead on the same throughout all shelves.
Next cut off the round corners with a jigsaw just outside pencil line & sand it until you reach the marks. I have a luxury of a belt-sander with a table but the job can be done just as good by hand sanding.
Step 7: Finsih
All that’s left is to do is finish sanding the whole project, apply some oil/lacquer of your choice (I didn't varnish the threads) and assemble it! In my case I used 2 part polyurethane varnish. It doesn’t yellow the wood & leaves the appearance of unfinished material while having very durable layer of protection.
If all went as planned by now you should have yourself a shelving unit! No glue or metal fixtures required! Just screw the shelves together in between these wooden bolts.
To get a better sense of how to put it all together you can watch the short video above where I take it all apart...
Congratulations!
Shelving Contest 2016
Third Prize in the
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    9 Discussions
    Henricus
    4 months ago
    Really like the concept! Well done! Did anyone try to do this with a manual wood threading kit? Wanted to get one and try but not sure will be accurate enough...
    boatmakertoo
    2 years ago
    Great idea. At one time the hardware stores sold wood turnings of various designs with threaded holes and threaded dowels to connect then through shelves as you have done. My favorite was a turning that resembled bamboo. These disappeared from the market long ago. Perhaps you could carve the outside of these dowels with your CNC machine to make them more interesting. A little lathe work would not be amiss.
    jcsevero
    2 years ago
    Contém uma
    Parabéns, gostei muito e vou fazer
    charlessenf-gm
    2 years ago
    Amazing what can be accomplished with automation. Most happy to see "sharing the g-code files." Puts me back in college Coding B.A.S.I.C. on a Tandy. We would come up with a cool bit of code and write it on the board for all to share and improve upon.
    Key was having the Tandy replace the Mainframe and Punch Card approach to interacting with the machine.
    I think the ability of these machines to create precision parts that can be designed so assembly is accomplished via interlocking parts - that might demand a specific/unique assembly order - might be the mst interesting prospects for CNC-Wood.
    JON-A-TRON
    2 years ago
    This is so well done. I've been wanting to repurpose one of our CNC machines to be able to mill the ends of material like this.
    I've done wooden threading before as shown in this project: Fireplace Coffee Table, but I used a manual tap and die. The way you're doing it, you can basically get any size members you want.
    Also, thanks for providing so much information on how it's done. You're a boon to Instructables!
    Andrius StaJON-A-TRON
    Reply 2 years ago
    Thanks for the good words!
    I've bumped into your Fire Coffee Table while researching wooden threaded designs a few years back. So it kinda played it's part in inspiring me for the TS1. Thank you for that :)
    astack
    2 years ago
    That is gorgeous. Love the rest of your designs as well!
    Henri.Lacoste
    2 years ago
    Beautiful and simple, had no idea you could cut a thread like that. Really lovely photographs too. Nice job! :)
    ScotP2
    2 years ago
    Pretty ingenious way to cut threads. Saves me from trying to build a 4th axis on my Shopeko.
