Table Saw Sled for Precise Angled Cuts
75,108
599
16
About: I'm a retired mechanical engineer, woodworker, boater, and inventor. Now I'm getting into wood turning, and have found that all my wood projects need not be flat and square.
There are plenty of table saw sled designs, here and elsewhere, on the Internet. A sled is an excellent addition to your table saw, and is usually intended to make precise 90 degree cuts. But occasionally you need to make a precise angled cut, as is required if you are doing segmented wood turning on a lathe. This Instructable shows you how to make a sled to make specific angled cuts on your table saw, more precise than anything you can buy for US$300.
Layout drawings in Imperial units are provided in the steps; layout drawings in Metric units included in step 7.
Step 1: What Do You Need?
The sled will be made from 3/4" MDF.
You will need a precise measuring rule, a good framing square, a drafting triangle and a sharp pencil. A magnifying glass will be a big help also.
Step 2: Make the MDF Rectangle
Start with a rectangle of 19" wide by 16" deep MDF. As in the photo, align the top edge square with the left miter slot. Use a framing square held tight against a 3/4" board fit tight into the left miter slot. Position the MDF so it extends an inch left of the saw blade. Place a strip of 3/4" wide x 3/8" thick x 17" long hardwood into the right miter slot, under the MDF. The width of the hardwood strip must be trimmed precisely to fit into the miter slot without slop. Place some shims under the hardwood strip to hold it just above the saw table.
Now that you have everything positioned, carefully lift the MDF, apply a line of glue on top the hardwood strip, and replace the MDF, making sure it is still square. Weight the MDF above the hardwood strip and wait for the glue to dry.
After the glue dries, trim off the excess on the left of the saw blade. You will now have the basics of an 18" wide x 16" sled.
Step 3: Layout the Base Lines
Use a SHARP fine point pencil for these steps. The critical dimensions will be shown precise to two decimal points; I used a rule graduated in hundredths of an inch, it will be OK to convert my decimal measurements to closest 1/64".  So if a measurement is shown as 2.00" for example, lay it out precisely.
Draw a vertical line 1" from the left side, top to bottom, parallel to the left edge of the MDF. This will be your vertical base line.  On this line, measure down 1" and make a fine pencil mark. Then measure down another 9.00" and make another pencil mark (see the drawing). From the 9.00" mark, use a framing square clamped to the left side to draw a fine horizontal line all the way across the MDF. It's important that this horizontal line be perpendicular to the left edge of the MDF (and so perpendicular to the vertical base line also). To check that it is, use the 3:4:5 triangle principle shown in the drawing below. When you have confirmed the horizontal line is perpendicular to the vertical line, measure over 16.00" and make another mark, as shown in the drawing. From that point, use a drafting triangle to draw a vertical line to the top of the MDF.
You should now have three baselines, two vertical and one horizontal.
Step 4: Layout the Angle(s)
The angled line(s) will be laid out mathematically. Best is to make one sled dedicated to one angle, the dimensions for three common angles used in segmented turning are shown on the drawing below, based upon the equation h = 16 * tan (angle).  So for the angle 15 degrees, h= 16 * tan (15) = 16 * 0.268 = 4.29". You mark the height h on the right hand vertical line, draw a line from that point to the intersection of the two lines on the left, and you have a line that makes a precise 15 degree angle with the saw cut line.
Step 5: Make and Attach a Fence on the Sled
 Now cut a 18" long strip of MDF 3" wide for the fence. Be sure the top edge is straight, I use the factory cut edge. You can glue this strip in place, aligned exactly under the angle line you marked, or if you want to re-use the sled for other angles, use screws. I used both glue and screws!
Be sure the strip extends past the left edge, then trim off the overhang.
Add a 2x3 to the bottom of the sled as a handle.
Step 6: Make a Stop for Measuring Your Cut Pieces
You will likely want some way to measure and duplicate cut length, especially for segmented turning.
This photo shows one way to make an adjustable stop; it has a miter bar strip underneath like the large sled,
Step 7: SI Units for Layout
These drawings provide metric units for layouts.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    16 Discussions
    Wired_Mist
    4 years ago on Introduction
    DIY at it's Best :) One of these days I'm going to have to make somthing like this for my band saw. Great Job !
    Bill WWWired_Mist
    Reply 4 years ago on Introduction
    You sure could make one for your band saw as long as it has a miter slot (likely).
    Now I'm glad I included metric dimensions.
    Wired_MistBill WW
    Thanks for the reply!
    Unfortunately, I have a Cheep band saw (brand specific accessories and a 62" blade over a 60" blade *frowns) It's this kind of situation that makes me want to make my own equipment :D
    It's just going to take some "Creativity" :)
    (Smile) "the 3:4:5 triangle principle"
    '(Right) Triangle principle,' right? (SMILE)
    Pythagorean Theorem, right? 'A' Square + 'B' Square = 'C' Square thus 9+16=25 and 'C' = 5
    Bill WWcharlessenf-gm
    Gee, I posted this in the wrong place the first time ...
    Thanks Charles -
    Glad you are smiling.
    Yes, Pythagorean Theorem, I had that in school several times (the theorem), but never really thought of the practical applications until I worked in construction and saw carpenters and pipefitters use 3:4:5 triangles to lay out square corners. They would have run me off the project had I started to talk "theorem" or "Pythagoras".
    April 2014 was Math Awareness Month (really).
    Bill WWSlickSqueegie
    Reply 5 years ago on Introduction
    Thanks; I made a test ring of 10 segments and can't see daylight between any of them.
    But when I first made the ring, I brought it in to show my wife. I assembled the ring (with her watching), and it was terrible, big gaps. Then I realized I had left one segment in the shop, I had a ring of 9 segments!
    rimar2000
    Good work, Bill. I made one similar for my new cutting table. But my table has not sled slots, I use the outer edges.
    I marked the angles I use on the table, but anyway always I need to do some tries and adjustments until to get the desired angle. To achieve this, I provided a micro-adjustment screw to the sled.
    Buen trabajo, Bill. Hice uno similar para mi nueva mesa de corte. Pero mi mesa no tiene ranuras de trineo, yo uso los bordes exteriores.
    Marqué los ángulos que uso en la mesa, pero de todos modos siempre tengo que hacer algunos intentos y ajustes hasta obtener el ángulo deseado. Para lograr este objetivo, he proporcionado un tornillo de micro-ajuste al trineo.
    Bill WWrimar2000
    Gracias Osvaldo.
    Siempre tenemos que hacer algunos ajustes.
    Tengo que hacer constantemente los ajustes en todo lo que hago.
    Y no sólo en el taller.
    I have to constantly make adjustments in all I do.
    And not only in the workshop.
    Bill WW
    Thanks Charles -
    April 2014 is Math Awareness Month (really).
    longwinters
    4 years ago
    Nice job, I like the way the depth stop doubles as a chip break to reduce splintering on the out board side
    Bill WWlongwinters
    Thanks, Longwinters.
    Added the length stop after making the sled itself; there also may be some safety advantages to it. When cutting really small pieces, they remain on the board and can me moved with the eraser end of a pencil.
    ldubia
    Thanks for your post. It was very well written and will benefit a lot of woodworkers.
    I noticed in your figures you listed 12.5 degrees for an 8 sided segmented ring but you listed 22.5 degrees on the angle. Just a typo I know. I just started doing segmented work and staves. I will give your sled a try. I prefer to have one sled to handle ALL of the different angles. Right now I have 12 sided, 16 sided (11.25 degrees) and 36 segments (5 degrees)
    Bill WWldubia
    Thanks for your comments! I know you read this Instructable well, you found my embarrassing error, which I will correct.
