Tea Light Candle Holders (with Storage)
9,199
213
18
About: A husband & wife team. Amateur makers. Expert high fivers. New video every week (or so).
We have a ton of tea light candles leftover from our wedding, but they burn out quickly and it's a hassle to dig up fresh ones. So we came up with this design to display them but also store extras so it's easy to refill.
We've broken this project up into gifs to give a quick walk through on how we made it. We messed up a few times (haha, ok a lot of times) and had some tips along the way so if you want that extra content check out our video above.
Supplies:
Step 1: Cut to Length
We first took some 1x12 pine and cut it to length on our miter saw (we did 6", 8", and 10") for each height of candle holder. We used premium pine so it required a little less finishing, but is still pretty cheap.
Step 2: Cut Segments
The main body is made from 6 segments cut at a 30 degree angle on both sides. At first we used a miter gauge to push the wood through our table saw, using a cut off as a spacer to get the width consistent (which was removed before the cut). This didn't work once the piece we were cutting started getting smaller though, so we ended up using a sled (we get into that more in the video).
Next we did a test fit. Everything seemed fine at this point, though we did notice the pieces tapered a slight amount... more on that later.
Step 3: Sanding and Gluing
We sanded all the pieces individually, making sure not to round the corners and edges (we wanted them to meet flush). We did some of this by hand and some with a random orbit sander. Then we used painters tape not only to hold everything in place, but also for the glue up (we used Titebond original wood glue). It's a really great way to hold pieces together in situations where clamps may not make sense.
Speaking of glue ups, this was a particularly satisfying one... though we maaay have used an excessive amount of glue.
Step 4: Making the Base
We traced the candle holder onto leftover 1x12 to cut out as a base. At first we tried to cut out the base on the band saw, but it was hard to be super precise so we moved to the table saw to get clean precise edges. We glued the base down with our favorite clamps.
Step 5: Cutting the Angle (optional)
It would have made sense to cut this angle before gluing the base down for sanding purposes, so we did for the final one (the first one we glued the base onto before cutting the angle, which was doable, just harder to sand). This step is optional - we did it because we think it looks cool and it makes it easier to grab the candles from the storage area. We did it by marking the angle with a protractor and very carefully following that cut on our band saw, making sure to go slowly and not over cut.
Step 6: Brass Rods
To support the top candle, we used brass rods. In an earlier version of this project, we had attempted to cut a small hexagon that perfectly fit recessed inside the top of the candleholder, but the brass rods are WAY easier and we think they are a nice aesthetic detail.
We cut two pieces of brass per candle a little longer than they needed to be with metal snips. Then we sanded them down on our belt sander little by little until they were the perfect length.
Next we used our drill guide to carefully drill through the sides of the candle holder (we used our digital calipers to measure the diameter of the rods and pick the right bit size). We inserted the brass rods through the holes and carefully hammered them into place with our mallet.
Step 7: Finishing
Shellac is our favorite finish, because it's pretty easy. When dry, it raises the grain slightly so we sand it with 600 grit sandpaper very lightly between coats.
Step 8: Enjoy!
Hope you enjoyed the tutorial!
You can also find us at:
Instagram (sneak peeks @evanandkatelyn)
YouTube (all our DIY videos)
Patreon (if you wanna support us, but no pressure!)
Pinterest (stuff that inspires us)
Blog (includes tutorials from our pre-YouTube days)
Twitter (us, in 140 character doses)
Facebook (be our friend)
Note: This post contains affiliate links. Thank you for supporting us!
GIFs Challenge 2017
Grand Prize in the
GIFs Challenge 2017
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    18 Discussions
    kylegilbert
    1 year ago
    Congratulations on the grand prize for this contest! Amazing build, and you guys totally rocked the animated GIFs!
    phillipnolan
    1 year ago
    i like the idea and the project, but cannot look at the page because of the visual cacophony of videos. The 80s called and wants their web page back. Please turn off the auto-play or at least let me turn them off. I will try again later.
    evanandkatelynphillipnolan
    Reply 1 year ago
    They're gifs so they play on a constant loop, unfortunately we can't turn off autoplay. Maybe the video would be easier to follow along with?
    phillipnolanevanandkatelyn
    Reply 1 year ago
    if the page does not give you the option to stop the autoplay, complain to the webmaster. this is the only page i have visited recently that autoplays gifs.
    aerospace4phillipnolan
    Reply 1 year ago
    It's a gif contest. What do you expect? BTW great project!
    Eh Lie Us!
    1 year ago
    great step by step instructions. I hope you guys wear hearing protection. Save your hearing!
    evanandkatelynEh Lie Us!
    Reply 1 year ago
    Thank you! We do! Evan has the big over-the-hear ones, and I (Katelyn) have this set of safety glasses with earplugs
    Eh Lie Us!evanandkatelyn
    Reply 1 year ago
    good to hear. (oh I really didn't intend that pun).
    I've been working with wood for a long time (mostly amateur work) and I have that slight ringing in the ears (tinnitus). It's easy to protect one's self. Take care and keep on building!!
    Cdub1
    1 year ago
    They are too cute and a fun idea......
    jeanniel1
    1 year ago
    Ha ha - looks like you had a lot of fun working on this - and LOTS of GIFs! Looks really good.
    evanandkatelynjeanniel1
    Reply 1 year ago
    Haha we did! Lol, since we made the video anyway, we thought maybe gifs will demonstrate the steps better than just photos, but definitely open to feedback!
    TwinDaddyD
    1 year ago
    This was my first time watching you guys. Loved your video! You two have so much fun working together. Keep it up!
    BTW, thanks for the candle holder idea. Looking forward to trying this one!
    evanandkatelynTwinDaddyD
    Reply 1 year ago
    Thank you! Haha we do have a ton of fun working together... even when we are messing stuff up :P Good luck on the project!
