Telescoping Minecraft Creeper Costume
292,815
355
46
About: A mechanical engineer by training, but often seek out fun projects at home to satisfy my need to create stuff. I love halloween, cardboard projects, and attempting to teach my kids that making stuff is much ...
Minecraft - its an obsession in my house. When my 8 and 10 year old kids aren't playing it, they are sharing the details of the Obsidian they just mined, or are drawing up plans for their next creations. So when it came time to choose this years Halloween costumes, the characters of Minecraft were an easy choice.
After carefully considering all of the available characters, including sheep, skeletons, or one of the many skins of Minecraft Steve, my daughter settled on a Creeper. I knew this would be a very cool looking costume - but I wasn't sure how practical it would be. The Creeper has a long body with 4 short legs to support it. Wearing a costume with a body section that extended to her feet would make it near impossible to walk - let along climb stairs when Trick-or-Treating.
We considered shortening the body so that the feet were closer to her waist. This would improve the mobility, but would definitely look a bit odd. After some brainstorming and multiple design sketches- we finally found the solution to our dilemma: a Telescoping lower body! It could be lowered when stationary and then raised up for walking.
With a design concept in hand, we set about making our Creeper!
Materials you will need:
* cardboard sheets
* Photoshop - or similar photo editing software
* sheetrock screws
* liquid nails
* scotch tape
* 3M spray adhesive
* Velcro
* Gorilla Glue
* scrap foam
Tools you will need:
* color printer
* straight edge
* utility knife and Exacto knife
Supplies:
Step 1: Get Your Dimensions
I've found that the key to making a great looking character costume is to have it scaled correctly. Without a Creeper action figure (does this even exist?) to measure, we downloaded one of the many papercraft templates that are available online. Papercraft templates are great in that they give you all of the dimensions you need on a single sheet of paper.
Once you've gathered the dimensions, you will need to then determine your scale factor. Since this costume is for my daughter, we took our key scaling dimension off of her. Our scaling dimension was measured from her shoulders to the ground. The thought is that the body portion of the costume is supported by her shoulders, and as a result the shoulders of the Creeper costume need to match this height.
The scale factor can then be applied to all of the dimensions from the papercraft template. You are now ready to start cutting cardboard.
Step 2: Make the Body
The Creeper character is essentially made up of rectangular box shapes. This makes cardboard the logical choice of construction material. Ít's cheap, easy to cut, and easy to fasten together with glue.
Our costume was made up of three distinct sections: head, body, and lower body. We started with construction of the body, which is itself constructed from three separate pieces. The front surface and side surfaces were made from a single piece of cardboard with two small flanges - one on each side - for easy attachment of the back surface. We attached the pieces together using liquid nails. Sheet metal screws were used to cinch the pieces together and hold them in place while the glue cured. This provides the added benefit of allowing the partially assembled box to be handled before the glue is dry.
Next the end cap was added. This too had flanges that were used for gluing to the body section. A square shaped hole was later cut into this end cap to allow my son's head to fit through.
Arm holes then need to be added on the side surfaces. Make these oversized to facilitate the process of putting the costume on and taking it off.
Helpful hint: We found that scoring the cardboard before bending to allow for much cleaner folds.
Step 3: Make the Telescoping Legs
The telescoping section of the costume needs to snug to the body, but still have the clearance to slide freely. We accomplished this by wrapping a strip of cardboard around the body. I placed some cardboard shims between the two sections to ensure there was at least some clearance. With the folds in place, I capped the lower section with a rectangular piece of cardboard.
Legs can now be added to the lower section. The legs are again made from cut and folded cardboard pieces. Flanges are used for attachment to the lower section.
Step 4: Make the Head
The head, which is essentially a cube, was constructed from three separate pieces. The first piece makes up the top of the head and three sides. The three sides fold down from the top surface, which starts to make up the shape of the cube. The edges are secured together with cardboard angles and liquid nails. Sheet metal screws are again used to hold everything together while the glue dries.
The fourth side surface is added and again attached with cardboard angles. If my cardboard sheet were large enough, I would have made this just fold down from the top surface.
Lastly, the bottom surface needs to be added. It has a square hole for a head to poke through. This is attached with cardboard angles.
Step 5: Add the 'Skin'
The first step is to make your skins. Our skins were made from images printed on a color laser printer, however any color printer will do.  We used a high resolution papercraft template as the source image for our Creeper (the one you used to get your dimensions may very well work). It took some time to find one that had a high enough resolution to not lose its definition when blown up to 16x its size.
Once you settle on your image, open it in Photoshop. Next open up a blank Photoshop file and set the canvas size to exactly match the dimensions of your surface of interest on the costume. For instance, each side of our head measured 14.00 x 14.00 so we set the canvas size to that for all surfaces on the head.
Back in the papercraft image, select the surface you wish to enlarge and paste it in the new canvas. Perform a free-transform to stretch it to completely fill the canvas. The file can then be saved to a .pdf. I have attached 3 of my .pdfs to this page. These can be scaled to meet the size you need. The body image can be used for all sides of the body with some trimming where needed.
The file can then be opened in Adobe and printed to a color printer. Be sure to print it with no scaling (100% size). To do this, select: Page Scaling>Tile Large Pages. You will have to trim the resulting prints and tape them together. The easiest way to trim the prints is with a sharp Exacto knife and a straight edge.
Before attaching your skins, tape all exposed seams on the cardboard with masking tape. This smoothes the transitions and covers the cut edges.
Use 3M spray adhesive to attach the skins to your cardboard. Again tape all of the exposed seams - but do so with scotch tape this time so that is not noticeable. As much as I love the 3M adhesive, it does tend to peel back at the edges over time. The tape prevents this.
Step 6: Assembly
There are two assembly steps:
Tethering the lower leg section to the body section:  A two foot length (approximately) of Velcro was used to tether these two sections of the costume together. The Velcro is secured to the lower leg section on the inside, near the bottom. It is attached to the body section on the inside, just beneath the arm hole. We secured the Velcro with Gorilla Glue.
Be sure to leave a short length of velcro at the top. This will be used to hold up the lower leg section of the costume when the wearer needs to have it up for walking. The Velcro mates with a small piece on the outside of the costume, mounted towards the top of the lower leg section. This may sound a bit confusing, but it  makes a lot more sense in the shown photos.
Tether both sides of the costume to evenly support the weight of the lower leg section.
Attaching the head: We attached the head with 2"strips of Velcro. This allowed for easy removal of the head (as required to eat candy during the various Halloween festivities).  The Velcro was bonded to the cardboard with Gorilla Glue.
Step 7: Finishing Touches
... almost done!
Eye-hole: Cut a hole in the head so that the wearer can see out of it. We cut along the pixel borders to keep it as clean as possible.
Shoulder pads:Foam was also added under the top surface of the body to prevent the cardboard from digging into my daughter's shoulders. This significantly improved the comfort of the costume
Enhancements and other ideas:
* Camouflauge the eye-hole: black screen or nylon stocking could be mounted to the inside of the head to hide the viewing cut-out.
* Give your Creeper a mortal enemy: Build a Minecraft Steve costume as the perfect complement to your Creeper! https://www.instructables.com/id/Minecraft-Steve-Costume/
4 People Made This Project!
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
46 Discussions
IzabelaK5
6 weeks ago
This is my creeper,but i'm not good as you.Many thanks from Italy.
pjkumponIzabelaK5
Reply 6 weeks ago
Looks great! Thanks so much for posting this! I really enjoy knowing that you made this half way across the globe!
eldaria
2 years ago
So this is my version, thanks for the tip of the teleporting legs. I added Sound, Smoke and Light effects.
https://goo.gl/photos/wjpPxXNVkuoyDSrJA
pjkumponeldaria
Reply 2 years ago
Wow! That is an awesome addition. I also love the moving head! You NEED to make an Instructable for how to do this! Thanks for sharing! and Happy Halloween!
MJ2007
2 years ago
I'm confused on how and where to add dimensions to this costume. Did you use the Papercraft website? Or is there a Photoshop trick I should know? I measured 48" from shoulders to floor, could you tell me where I should add this to get the measurements for the rest of the costume? I'm sorry if I'm missing something that you already included in there! This is so cute and I want to make sure I get it right. Thank you so much! :)
big_buddhaMJ2007
Reply 2 years ago
I took the papercraft template into illustrator (or photoshop if you
don't have that) and the I just scaled the paper template. Keep in mind that the costume is telescoping, so you might just wanna figure out the depth of the body (i.e. my daughter is 40" from shoulder to floor so I went with 8" depth and made sure it fit her body with room to move) and then just made 2 units for the body that is 20" and 16" tall. I eyeballed this plan and figured the legs are attached at about 1/3" of the way, so I measured from the bottom of the feet to the top of the body. I also made sure there was at least 3" overlap between the telescoping body parts at the max height (40"). Then you just take the ruler tool and measure
the width/height off the paper template for the rest of the dimensions.
Check to make sure it fits the person who will be wearing the costume.
You might need to just tweak it on the fly. You want to make sure the width of the costume (shoulder to shoulder) is appropriate and then that's the size of the head. Really, don't stress too much, eyeball/estimate, have fun making it and your kid will love it!
VictoriaB72MJ2007
Reply 2 years ago
Did you get any help on this? I find myself having the same question.
heyytawnyy
2 years ago
Do you have the PDF skins like the Minecraft Steve costume?
pjkumponheyytawnyy
Reply 2 years ago
I don't have them any more. Just search Google for "Minecraft Steve papercraft" and use the advanced features to search for large size images... this will give you the highest resolution.
tab328
3 years ago
The telescoping legs was brilliant, I was thinking about doing a life sized zombie but that's a bit big; the head would be about 1.5 feet cubed. A life sized creeper might have enough room to shuffle but that's pretty big too. Although I'm not making a wearable creeper, I'm still going with a creeper, just making it remote control and about 4 feet tall.
I really want to tell my parents that I will get all the cardboard and scrap foam I can get to have the Creeper and the Steve Costume!
(Too bad I need help from family and my brother probably will laugh at me wearing it)
ironmanlover
4 years ago
Can you please send me the measurements and give me the templates please. Amazing job
schamberlain4
4 years ago
We used felt squares to make the pixels. My 4 year old loves it although he still calls it a teepor lol
melizer
4 years ago
Thanks for the instructions. We were huge hit Trick or Treating!
pjkumponmelizer
Reply 4 years ago
oh man! that is great! You made my day by posting! It looks like you made the telescoping base for the creeper too! Very well done.
melizerpjkumpon
Reply 4 years ago
I did! My son is only 4 and the weight of the cardboard was difficult for him so we left it off for actual trick or treating time. Here is a pic of the telescoping legs on
