Temple: Placing the Columns
Now it's time to place the columns.
Instructions
  1. Find the columns and select them.
  2. Continue to the next step.
Step 1: Move the Columns
Continue positioning the columns.
Instructions
  1. Move the columns so that they cover the gaps between the walls/arcs.
Step 2: Copy Pointed Dome
Time to add the pointed domes.
Instructions
  1. Find the pointed dome and position the camera to see the bottom.
  2. Press W to choose the Workplane Tool and select the bottom surface.
  3. With the pointed dome selected, press CTRL+C to create a copy in the clipboard.
  4. Continue to the next step.
Step 3: Paste Copy of Pointed Dome
Make more copies of the pointed dome.
Instructions
  1. Press W to choose the Workplane Tool and select the top surface of the column.
  2. Press CTRL+V to paste a copy of the pointed dome on top of the column.
  3. If the dome is pointing down, rotate it so that it is pointing up.
Step 4: Continue Adding the Domes
Keep up the good work, continue adding the domes.
Instructions
  1. Make a duplicate of the pointed dome and move it to the opposite column.
Step 5: Copy the Column Base
Now we need to add the column base to each column.
Instructions
  1. Copy the base of the columns to cover the next two corners of the wall/arch.
Step 6: Copy the Small Dome
Repeat the process to the small dome.
Instructions
  1. Press W to choose the Workplane Tool and position the camera to see the bottom of the small dome.
  2. Select the bottom surface of the dome.
  3. With the dome selected, press CTRL+C to copy small dome.
Step 7: Paste the Small Dome
Instructions
  1. Position the camera to view the uncapped column.
  2. Press W to choose the Workplane Tool and select the top surface of the column.
  3. Continue to the next step.
Step 8: Paste Copy of Small Dome
Instructions
  1. Press CTRL+V to paste a copy of the pointed dome on top of the column.
  2. If the dome is pointing down, rotate it so that it is pointing up.
Step 9: Duplicate Small Dome to Other Side
Instructions
  1. With the small dome selected, make a duplicate of it.
  2. Move the duplicate of the small dome on top of the opposite column.
  3. Continue to the next lesson.
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
