Tent Rainfly Modification
4,316
21
The purpose of this Instructable is 3 fold.
1) Improve air circulation and help remove condensation buildup inside the tent. As well as keep any condensation that does form away from your head/feet.
2) Add stability to the tent in high wind environments
3) Help shed rain away from the base of the tent.
This is accomplished by pulling the front and back of the rainfly away from the base of the tent.
Step 1: The Improvment
The first picture shows the tent as usual. Don't get me wrong, this tent is the best I've ever owned, but there is always room to improve. The grey panels are the doors (sides) and the green panel is the front/back. It is the green panel that we are modifying. It will be pulled out via guy line to keep it taught and allow for air to flow into the tent.
Step 2: Measure It Out!
The first step is to find the center point of the rainfly panel you want to guy out. In my case, the panel was 71" long, so I marked 35.5" (half way). We are applying the glue and loop to the underside of the rainfly panel, so be sure you have it oriented correctly.
Step 3: The Materials
Essentially, what we are doing is adding an attachment point to the front & back panels to attach a guy line to. The materials we will be using are pictured...
paracord (material used for the attachment point)
2 clamps
wax paper
Shoe Goo (I LOVE this stuff)
scrap wood
-1 board as a working surface
-2 flat pieces to press everything together evenly
-1 pieces to spread the glue
Step 4: Apply the Glue
Stretch the rainfly, underside up, over the board. Add glue to both the rain fly and the paracord.
Step 5: The Glue Up
Carefully place the glued surface of the paracord to the glue on the underside of the rainfly. Lay wax paper on both sides to prevent any leak out. Then hold a piece of flat scrap wood on both sides to allow for even clamping pressure to the whole assembly. Finally apply the clamps. See order below
Clamp
Wood
Wax paper
Rainfly
Glue
Paracord Loop
Wax Paper
Wood
Clamp
Step 6: Attaching Guy Lines
The first photo shows the loop attached to the rainfly after it has dried completely as well as the guy line material.
The next step is to attach the guy lines. I choose to use bungee cord to help absorb and stress put on the tent due to wind. You could certainly use a traditional guy line cord like paracord or bankline. I have two loops of cord pictured. One will be attached to each end of the bungee guy line and hook around the tent stake.
I found the easiest way to attach the bungee guy line to the newly created tent attachment loop is to make an overhand loop in the paracord line then feed the bungee guy line through it as seen in the second photo. Simply flip the loop over the bungee cord and you have essentially created a square not, see photo 3.
Repeat on the opposite end for the loops that attach to the tent stakes Photo 4. Alternatively you can simply tie a loop in the end of the bungee directly or attach a triple slide line tensioner
Step 7: Finished Product
Thats it! You now have a tent that allows for more airflow to eliminate condensation buildup, is more stable and directs rain away from your floor more effectively. This method can be used for all sorts of other mods requiring additional attachment points. I would just encourage you to attach loops on the underside of the rainfly whenever possible.
Happy Camping!!!
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Discussions
    seamster
    4 years ago on Introduction
    Nice fix!
    Any thought to sew the paracord loops to the rainfly? I love shoe goo too, but wonder if having it stitched on might be a longer-lasting fix. I'm just thinking out loud here! :)
    tgreen588seamster
    Reply 4 years ago on Introduction
    Seamster,
    Thanks for the kinds words and suggestions, always appreciate alternative approaches.
    I did consider stitching and have done both in the past, shoe goo & sewing, on a project to add sleeping bag attachment loops to the bottom of a backpack. From a strength and durability standpoint it is absolutely the best of both worlds.
    The reason I decided to go with the shoe goo on the underside of the rainfly was to avoid compromising the waterproof liner of the rainfly. If I were to stitch and then coat the top of the stitches with a shoe goo to re-waterproof it, it would look a little unsightly. Just my opinion, would love to hear some feedback from someone who did this project with stitches as opposed to adhesive.
    Thanks again for the feedback!
