Textile Trackpad
5,033
79
14
About: A curious human.
Functional fabrics can do things like light up, heat people, and sense when they're being touched. This project was developed to show how functional fabrics can be used for applications far beyond apparel and can also be used as design tools.
The Textile trackpad can be used to replace a computer mouse and could, in theory, be used to model, sketch and draw in the computer. This one is just hooked up to a processing sketch, but if you make your own, I'd be curious to see how you make it function!
To make the trackpad textile, you'll need the following things:
  • Bare conductive ink,
  • Flora microcontroller
  • Embroidery TPU
  • 4 Adafruit 12 Cap Touch breakout boards
  • 10mm conductive fabric tape (3 rolls)
  • Nail Polish, or liquid electrical tape
  • iron on interfacing (soft)
  • A Cover textile
  • Heat Gun
  • Soldering station
  • USB mini connector
  • Gauge 30 silicone thread
Step 1: Solder Your Electronics
To make your textile trackpad, you'll need to spend some time soldering together the circuit. See the diagram above for how the layout is done. I added vibration motors to shake when you touch the textile, but it's up to you to add any special features!
For the cap touch breakout boards, each one can have an individual address, so you'll want to solder them all to the same clock and data line and then solder pins together on the board to create the unique address.
Step 2: Lay the X Axis
Once the electronics are assembled, you can lay out the X axis by ironing together the embroidery insulation and laying on the conductive fabric strips across the X axis
There should be 17 strips spaced 1.5" apart. Once they are all placed, you can insulate with nail polish where the Y axis will cross (this may not be entirely necessary).
Step 3: Insulate the Y Axis
Place the 23 Y axis strips onto the lightweight interfacing and cut back into strips. The interfacing on the back keeps the X and Y axis from conducting together. You should have 23 strips with backing ready to place.
Step 4: Add the Y Axis
To place the Y Axis, make sure to mark placement lines on the embroidery material. You'll want to place them at a 1.5" interval and ensure they are straight from top to bottom. They can be held in place with double stick tape.
Step 5: Connect Axis to Electronics
To connect each wire to the conductive fabric pieces, you'll want to use a conductive adhesive like Bare Conductive. We placed this at each joint and let it dry. Then, we tested the connection to ensure it would properly conduct.
Step 6: Test
After assembling the grid, you'll want to test it with a simple example sketch that comes with the 12 Cap Touch breakout board. You can touch each lead to ensure it is registered by the MCU and the IC.
Step 7: Press Together Entire Tablecloth
This is where it all comes together! Hem your piece of cover fabric and place on top of the embroidery interfacing. The sticky side should be up. Use an iron or a heat gun to melt the embroidery adhesive and press down the wires and X,Y strips.
Step 8: Program Electronics
Next up is programming the Flora. You'll want to download the 12 Cap Touch library from Adafruit and install. I changed by settings to be more sensitive in the header file and programmed it to have mouse control.
Step 9: Interact With Your Computer in a New Way!
Use the "trackpad" to control your mouse and interact with your digital world in a a new way!
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    14 Discussions
    Heipoe
    Question 1 year ago
    Hi! What are embroidery TPU and iron on interfacing, please?
    MaddyMaxeyCordyMango
    Reply 1 year ago
    Im still cleaning it up! I'll post once it's ready.
    RejutkaMaddyMaxey
    Reply 1 year ago
    I'm also interested in the source code.
    Especially the values for the sensitivity settings. (And how they're set, unless it is simply setThresholds.)
    StevenB119
    1 year ago
    Very interesting. Do you think it would allow for multitouch?
    MaddyMaxeyStevenB119
    Reply 1 year ago
    It probably could if it was programmed to do so. I would imagine that the code would need to look for touch zones and be able to categorize which zone a series of touches are coming from to identify what the right hand is doing, and what the left hand is doing.
    RejutkaMaddyMaxey
    Reply 1 year ago
    So, if I'm reading this correctly, (and finally understood how these touch sensors work) - it should be fairly simple (I'm tempted to say easy) to create a keyboard using this technique?
    A "normal" keyboard using switches needs a more complicated circuit, to avoid ghost-keys from current flowing "back" across other routes.
    Unless I'm misreading this, this uses several dozen individual lines that don't allow cross-flow, eliminating this problem without the bother of adding lots of diodes.
    EdouardC5
    1 year ago
    Nice job ! Do you know if there is any "ghosting" effect as for resistive sensor arrays ? Another question : is there any alternatives to Bare Conductive ink to link wires and foils ?
    MaddyMaxeyEdouardC5
    Reply 1 year ago
    Hmm, I don't know. I hear about phantom capacitance. I wonder if it's similar.
    MaddyMaxeySalvagione
    Reply 1 year ago
    Paolo! Alas, it's not manufacturable yet, but hopefully soon :). I hope you've been well!
