The Boominator: 360° of 115dB Music
87,489
607
90
Hi there and welcome to the Boominator Buildlog.
This is the pinnacle of boomboxes that me and my friend have been working on for the last couple of months. Many days were spend building this beast. What makes it so great you may ask. Well, multiple things:
- Capable of doing 115 dB at 1 meter
- Capable of sustaining full output for at least 20 hours.
- 360 degrees of sound
- Excellent bass performance outdoors
- LED strips around the woofers perimeter that flash on the beat
- And many more small things
Building it was almost as fun as seeing and hearing the final product :)
Before we begin the buildlog I want to thank:
-AccuSafe for supplying most of the parts and having awesome customer service
-User Saturnus for doing the audio engineering behind the design
I'll be referencing to pictures with [..]
Supplies:
Step 1: Preparation
Beginning a DIY build without proper preperation is a recipe for disaster. So that's where we start.
In the first picture you can see our cardboard mockup which we used to get a feel of its size and form factor. It measures 90x30x30 (triple cube, 81 liters). Pretty big, but small considering the performance. Essentially its a portable PA setup. The sketchup drawing of the design can be found here: https://3dwarehouse.sketchup.com/model.html?id=ed70429792f0ff9d421ffb972735edc
After placing our online orders we went to the local hardware store to get our 12mm 9ply birch plywood cut [2]. Man that stuff is strong.
A couple of weeks later our orders arrived. The 4 10" P.audio woofers [3+4], battery, PSU, amplifier and battery protection [5], and some general cable stuff.
Step 2: Start of Construction
From cardboard to wood. You can definitely see it getting shape now. The Boominator drivers are mounted back to back (bipole), with the magnet against the centre brace. This makes the construction very sturdy. To reduce weight, connect the two chambers and increase total chamber volume the centre brace needs to have holes in it [2] and a cutout for the handle on the side.
The handle doubles as a bassreflex port (the other way around really ;p) so it needs to have a specific size [4], otherwise it'll mess up the tuning. We cut out it using a jigsaw [5]. In picture 6 you see us rounding over the exits to reduce port noise and to get a softer grip.
Then we glued and screwed the side piece and centre brace to the baseplate [7] and repeated it for the other side [8].
Step 3: Circles, Holes and Rounds
The router was our best friend at this step. It's very difficult and tiresome to make (good) circles with a jigsaw.
Drawing it out [1], using the router with our DIY circle jig [2], testfitting the woofer and wood with a grill sandwiched inbetween [4].
Time for another mockup [5]. As you can see, this thing is a beast.
In the last two pictures we're trying out our LED strips.
Step 4: Testing and Mounting
We hooked up the woofers to see if they all worked. Once they're mounted they should last a lifetime. The upside of such a strong construction is that they probably won't be damaged. The downside is that if we manage to get them damaged, swapping it out is next to impossible.
The next picture is of our piezo tweeters. Huh, piezo tweeters? Aren't those that horrible type that sound like plastic? Yup, if you don't know how to use them they are. We filled up the grooves with sealant to prevent resonance [2]. Because piezos are capacitive elements we can use a simple resistor to create a first order RC highpass as crossover; cutting of the first 'plasticy' peak and reducing the power consumption by a small bit. Their natural response is 3.5kHz and up, which is where our woofers start to drop their response. Perfect fit!
In picture 3 the woofer and tweeter are mounted with acrylic sealant, which is drying in picture 4.
Step 5: Prepping Electronics
While we left the speakers drying we grabbed the soldering iron to prep the electronics.
To save the speakers from unneccesary excursion at frequencies it can't really reproduce we modified the highpass on our high efficiency class-D MaxAmp20 by removing some of the input capacitors.
The amplifier is 90%+ efficient and can output 2x15W in 4 ohms. This doesn't seem like a lot, but this system is so efficient that it puts out 101 decibel with 1 watt at one meter. So if 1W is already very loud, imagine how loud 30W is ;p.
Then we, or my friend really, assembled the AccuSafe [3]. He never soldered a printed circuit board (PCB) before, but it turned out great. The AccuSafe is a PCB with a comparator circuit and a relay onboard that cuts off the power the the electronics at 11.5v to prevent battery damage. It also switches to PSU/charger when available.
The front of our electronics compartiment will be wrapped with carbon. We tested our wrapping skills on a test piece first [4] and then proceeded to our real front piece [5]. From top to bottom: off/led/on, volume knob, 3.5mm input, LED switch, cigarette socket.
The cigarette socket can be used for a USB charger, voltmeter to check battery status or of course a cigarette lighter.
Step 6: Assembly
Now we get to the biggest part: assembly. In picture 1 you can see why it's so strong. It can't flex along any axis.
The grey stuff on the speaker magnet in picture 2 is chemical metal. It is very strong, very stinky and very chemical. As you can see we already wired up the woofers to the tweeters. Later they will be wired in pairs to the terminals you see on picture 3.
Next thing you know: it's assembled. Now it's time to wire it up; the tape over the speaker is to prevent hot solder from dripping on the cone while soldering. The speakers need to be wired in phase: each speaker needs to move towards or away from the center at the same time.
Step 7: Painting and Electronics Compartiment Wiring
These steps need more pictures than words.
The LED strips still shine bright despite the slightly painted parts. We used Warnex/Duratex, a very durable type of structured paint that's often used with pro-audio gear.
After a bit of testfitting we wired everything up. We used multiple meters of wire ;p. The cutout on the right is to slide over the terminals. It worked out perfectly in the end. The backside with the 230v input, LED strip controller sensitivity knob and name plate on it sealed the compartiment off. It's jammed in there as you can see.
In the last pic we are testing it out, the module is behind it.
Step 8: The Final Product
Hope you enjoyed the buildlog. Please vote on our project for the DIYaudio2015 contest if you liked it.
If you have any questions/comments don't hesitate to ask
DIY Audio and Music Contest
First Prize in the
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    90 Discussions
    jneave
    4 years ago on Introduction
    Hi,
    Saw this on the facebook Instructables page and we've been trying to figure out how to build something like this for a very long time.
    So, we're going to build this as a learning experience.
    Can we get some more details on the electronics side of it?
    Specifically which amplifier boards you used, as well as the lead acid charging board?
    Thanks.
    lutkeveldjneave
    Reply 4 years ago on Introduction
    This is a very good beginner project, but be prepared to spend a lot of time on it ;p.
    Everything is 12V powered and tied into a central star. The charger is a H-Tronic 800mA from Conrad with stripped cables. Input to the IEC plug on the backside, output to the Accusafe (which couples it to the battery).
    There is a lot of flexibility in the electronics side of this build. If you're serious about building one you can shoot me a PM and we can work out a Bill Of Materials based on your preferences. You can also visit the main topic on DIYaudio.com and ask some of your questions there.
    jneavelutkeveld
    Reply 4 years ago
    Hi,
    Most definitely we're very interested. For years we've been mulling the design for what we've named The Rucksack Rig. But due to lack of experience we've been unwilling to pull the trigger on an untested design with no practical experience.
    Sadly I'm pretty damb ill at the moment. Hopefully a few weeks/months I'll see some improvement. No idea how in supposed to pm you. Didnt even get notification about your reply!
    Got several interested party people now. Hopefully I'll be better soon and we we can get started. It's much easier to contact me on Google Hangouts of you use it. I'll try to PM my address
    lutkeveldjneave
    A speaker in a rucksack definitely rucksucks. Time to be blown away by quality construction :) Click my name, somewhere on my profile page should be the private message button.
    jneavelutkeveld
    Reply 4 years ago
    The rucksack was just for transport! Also accessories. stage 2 will be one of those quarter wave folded horns called the suitcase sub.
    narnbakjneave
    Reply 2 years ago
    We have a rucksack rig in case you're interested :)
    http://infaders.com/
    thomas2016
    3 years ago
    Hi man,
    One of these has been on my list for some time now & finally have the funds to get the parts, as you have gone through the pain of finding suppliers in the EU would you help me out with a BOM and where you got them from?
    Nice build & writeup
    Thanks
    Tom
    gabrielkyne
    3 years ago
    Incredible build.. I want to make one but I don't feel like I have the experience. Got any tips for me? What do I need to learn before I can understand how to build this from the info in your guide?
    lutkeveldgabrielkyne
    Reply 3 years ago
    Read up on some basic electronics to know what's what so you don't blindly do things. Also read the Boominator thread on DIYaudio.com, it's large but it's worth it. It's full of questions of people like you, make annotations along the way so you can refer to them later. If you don't know certain things you can send me your questions. I can't help you with everything because it's too much. Ask detailed questions and I'll help you further. See it more as a learning project than only doing it for the outcome (a nice speaker). Otherwise you'll get frustrated really fast ;p
    gabrielkynelutkeveld
    Reply 3 years ago
    Hey, that sounds great. I've been wanting to gain that knowledge anyway so this will be a nice start. Do you have some resources you can suggest. A beginners book on electronics maybe?
    Reply 3 years ago
    Electronics for dummies is a good place to start. You can also get really far by just doing a case study on every word you don't know. Let's say you're reading the Boominator thread and come across a word you don't know: write it down and research it until you know what it means.
    Loved the tutorial, i did make something like this just in a different style, those speakers look amazing as you said it can output 115db!!!! and for a dual 15w amp!!!! i used a dual 40w +68w sub-woofer connection.
    Dalletheman
    3 years ago
    Dont know if I missed it but what kind of resistor do you use for the filter?
    JonasH4
    3 years ago on Introduction
    Hey I made it and this speaker is simply Awesome! Soundquality, Loudness, Playtime huge win in every term exept the size xD but i think i will mount some wheels for transport.
    Van Damage
    3 years ago on Step 8
    Man that is an amazing looking build, good job you guys. It looks sweet!
    jedwards2
    4 years ago
    Hey I'm interested in making a boominator of my own after reading this and most of saturnus's thread. Could you you help me put together a list of materials?
    chemacky
    I notice the original boominator has solar panels - are they easy to add into this design? For example, I have an 18v 28w solar panel that I'd love to be able to use to charge something like this on the odd occasion. Not permanently built in. Could the accusafe deal with the power of something like this solar going straight in instead of the mains?
    lutkeveldchemacky
    Reply 4 years ago
    Yes you can. With higher power panels like yours its recommended to use a charge controller. You only need 10W to make the battery life 'infinite'.
