The Force Awakens Knife Block
5,718
149
12
About: My sister and I like to make things! And even more than making things, we like to share our creations! We want to create beautiful and compelling content that really helps people to get what they need!
Need to spice up your kitchen with a little bit of personal style? In this Instructable, we will create a unique Star Wars - The Force Awakens knife block that stars Kylo Ren using the force! If you stumbled upon this Instructable and aren't a Star Wars fan, just go ahead and make it anyways :D
Materials
  • Knife Set*
  • About 2-3 feet of 3/4" Plywood
  • Paint (optional)
Tools
  • Printer
  • Jigsaw
  • Sander
  • Wood/metal File (helps round out the tight corners)
* You can support us using that Amazon Affiliate link!!
Supplies:
Step 1: Cutting Out the Dark Side
  1. Print off Kylo Ren (above)
  2. Spray 3M adhesive of on the back of it
  3. Press it against the piece of 3/4" plywood
  4. Using a jig saw cut out Kylo Ren
Step 2: Cutting Out the Force and Base
  1. Cut out a 8" (point to point) Hexagon out of 3/4" plywood
  2. Cut out a 11" x 7" rectangle out of 3/4" plywood
  3. This is where you can route the edges of the base and force to give it a more futuristic look
Step 3: Drilling Holes for the Connection and Knife Slots
  1. Cut a square roughly 0.3" into the back of the Force hexagon, dead center
  2. Cut out the slits for the knives by first drilling several holes in a line with a tiny drill bit
  3. Using a razor, slice the uncut plywood between the drilled holes
  4. Clean out the razored cuts with a file
  5. Once the slit is large enough, fit a jigsaw blade inside and finish cutting out the slit for the knife
  6. Clean up up the slits with a file and make sure the knives fit snug
Step 4: Sand Everything and Paint
  • Give everything a good sand with 120 grit paper
  • Brush all of the dust away
  • Apply a primer coat, leaving the edges of the plywood unpainted
  • Follow the primer up with 2 coats of high gloss black, also leaving the edges of the plywood unpainted
Step 5: Assemble the Force
  1. Mark where the Kylo Ren will be standing
  2. Pre-drill two holes into the base where the feet were for screws to go into them
  3. On the underside of the base, drill a counter sink hole
  4. Screw Kylo Ren to the base from the underside.
  5. Rub some glue into the hole that was drilled in the dark side
  6. Slide the dark side onto the end of Kylo's hand and clamp in place
Step 6: Sealing the Deal
  1. Apply two coats of Polyurethane for a nice sheen and sweet finish to the plywood!
Step 7: The Force Awakens
You now have a really sweet looking knife block that you can show off to your family and friends, and be super proud of!
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    12 Discussions
    Donutman77
    3 years ago
    I think that you should modify it so that he's using the force instead if using a shield.
    PatrickW51Donutman77
    Reply 3 years ago
    I know! I was trying to think of a way that made the knifes look like they were being held by the force but doing that and trying to hold them firmly was a tough task to tackle. So I opted to try and make the "shield" look like what we would perceive the force to be if we could see it :)
    PatrickW51tinaciousz
    Reply 3 years ago
    Omg I know! After I made it, I was like, I shoulda used my 1/4" polycarbonate instead. Would be wayyyyy cooler. Knife block Part 2??
    PatrickW51
    Reply 3 years ago
    Hahah good point, I will add that :) Thanks for the tip
    PatrickW51
    Reply 3 years ago
    Cutting the holes for the knives was a bit tedious but a good learning experience. I used a tiny 1/16" bit and drilled a few holes in a straight line. Then i used a razor blad to cut away between the holes, then I used a file to file away the inside to make a straight slit. Then I pushed the jigsaw blade through the hole I made and cut the rest of the slit.
