The Magic Bottle
42,287
168
19
Print your own Magic bottle
Step 1: What Is Magic Bottle
Pour water again and again from an empty 3D printed plastic bottle! Pour a quantity of water from the bottle, seeming to empty it, moments later pour a quantity of water again !
Step 2: Design
The concept is to include upside down internal chamber/ chambers
inside the bottle that can hold some liquid when the bottle is tilted and held upside down
Step 3: Liquid Transfer to Main Chamber
When the bottle is upright again, liquid is transferred from the small chamber to fill the main chamber again.so that when the bottle is held upside down again, the liquid is free to pure out of the bottle making a great illusion leaving the audience in doubts where this liquid come from?
Step 4: Different Internal Design
You can add more than one chamber, at different orientation, you can really play with the design making it very interesting and able to pour multiple times adding more excitement. I decided to experiment with a C shape section adding holes at different angles.
Step 5: Printing the Bottle
I used a reprap 3D printer to prototype the bottle, I am sure almost any 3D printer can do it, make sure you chose the right settings to produce an air tight bottle that does not leak.
    • Pocket Sized Contest
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    19 Discussions
    askjerry
    3 years ago
    You could have a tube the size of the opening extend all the way to the bottom. The slot where the water/liquid fills the chamber would be a certain height... that height would determine the amount of liquid available in the center. As the outside chamber would hold much more than the inside chamber, each pour would result in the liquid running in until the air could not escape to the outside chamber again... so each pour should be about the same amount... likely a 5:1 ratio would give you at least four pours of the same size.
    Samithawabaaskjerry
    Reply 3 years ago
    I thank you for your comment, Remember there are many ways by which you can make this trick, but I appreciate the time you took to put this comment, however I did not get it 100%, would you please provide me with a sketch that explain your point. thank you in advance.
    askjerrySamithawaba
    Reply 3 years ago
    Here is an AutoCAD cross section and a PNG I made from 1/2 the model. The fluid will only go as high as the slot... and the outside area is about 5x the slot height... in theory at least 4 equal pours, then each additional pour would get smaller.
    Samithawabaaskjerry
    Reply 3 years ago
    wowwwo, that is very cool, thank you very much
    SamithawabaSilverfieldwolf
    Reply 3 years ago
    100% agree, I was thinking about doing it and sharing it with the rest of us, you can do it with plastic bottle and some glue gun ! , keep me posted
    the norm
    3 years ago
    I have a commercial version of this made of metal (I am a member of three magic organizations). If I was to make one, I would try to have the storage compartment a lot bigger than the chamber it flows into. I find with mine that I can pour a lot once, then quite a bit less, then less and less. It would be nice to have a large enough reservoir so the first few pours were more equal. I am not sure what the design problems would be, though.
    Samithawabathe norm
    Reply 3 years ago
    That is a pretty damn good idea, I can not agree more, let me see what I can do with the Design. I got 2 more ideas and products coming soon
    big thx for the comment.
    Samithawaba
    3 years ago
    I am loving this, today I printed something similar, wait for it , will be with you soon :)
    Egret03
    3 years ago
    this is so cool, I would totally try it if I had a 3d printer!!
    lgooms
    3 years ago
    This is neat. Are you able to get colored water into one of the chambers?
    tkjtkjlgooms
    Reply 3 years ago
    Neat idea! peeking at the advanced one, with multi chambers, sure i bet ya could have diff colors in each chamber ... and rotate the bottle properly when pouring!
    I do suspect, though, that two diff color water might trigger the 'somethin's FISHY' response... having your audience figure out quickly what must be happening ..
    Nice project! thanks!
    Samithawabalgooms
    Reply 3 years ago
    you can not get colored water out of this, as water will be mixed together, but you know what, you just inspired me wait for it soon :)
    SamithawabaDr.Webb
    Reply 3 years ago
    to design it, I used Solidworks, but you can use pretty much any 3D designing software
    lglira
    3 years ago
    Great project, this could be usefull for anti slip blottles
    ramiz2
    3 years ago
    this is so cool, i like, thanks for sharing
    seamster
    3 years ago
    Very cool illusion, I love stuff like this. Thanks for sharing the print file!
