The Most Awesome Chisel Rack Ever
8,318
161
33
About: i am Patrick from Patrick's Work Shop on youtube where i like to build lots of cool shop projects and other fun projects click on the link to see more https://www.youtube.com/user/Patricksworkshop
Hi My name is Patrick from Patrick's Work Shop and today i'm going to show you how I made my most awesome chisel rack ever , lets get started
Step 1:
first you will need some wood I am using a scrap piece I have on hand it measures 1"x 3" and its 30 inches long
you will also need the chisels you want to use on this rack
Step 2:
Lay out your chisels how you want them to be on the rack and get a measurement of the length you will need . I have more chisels than I probably need but i needed a place for all of them ,so mine is 24 inches long your length will vary. Cut off one end to square it up .Then using a tape measure mark your board to length and use a speed square to square up your line
i'm using a Radial Arm Saw but a hand saw or chop saw will do the same thing cut your board on the line
Step 3:
next you will want to lay your chisels out again ,this time put them exactly where u want them on your rack
using a pencil and the chisel to mark the lines on each side of the chisel to define the cut
Step 4:
using your speed square mark all the lines across the board where your dados will be for each chisel
be sure to mark the cut area so u don't get confused where the cuts will be
Step 5:
I'm using my RAS but a table saw or handsaw and the chisel to cut out the waste out will work
I'm cutting only the thickness of the chisels ,I want the chisels to sit flush to the surface so set your saw depth to the thickness of your chisels
Step 6:
after the dados are all cut to fit the chisels tight layout the chisels in there places
you will need a 3 inch wide piece of plexiglass to go over the chisels
mark the length you will need and cut it to size
Step 7:
in this step you will be drilling the plexiglass holes slightly oversized for the screws to fit loosely so the plexi don't crack when you tighten them down
You can do this free hand or in a drill press i used a 5/32 " drill bit to drill the plexiglass
Step 8:
after the plexi is drilled you will want to drill the wood using the plexiglass as a template for drilling the wood
i used a 1/8' drill bit for drilling the wood i drilled a few holes and added some screws to hold the plexiglass in the right spot for drilling the rest adding screws to the ends to keep the plexiglass from bending or cracking
Step 9:
in this step you will add screws to all the holes , i am using pan head screws 3/4 inch but you can use any you have on hand
Step 10:
last step hang up your chisel rack in a good spot and enjoy the most awesome chisel rack ever
Thanks for checking out my first Instructable
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    33 Discussions
    Jlfenter
    3 years ago
    Really simple, really neat. Thanks for sharing...
    Jlfenter
    3 years ago
    allangee
    3 years ago
    Make sure you leave a little extra room so that the cutting end of the chisel doesn't rest against the wood. It'll keep its edge longer with less contact (obviously) and the gap will keep any minute mounts of moisture off the edge. Great concept!
    gerrywatts
    3 years ago
    Thanks thinking of building one of those in my garage.
    HobbyJim
    3 years ago
    My favourite part of this is your use of recycled materials. I, too, have a stack of old furniture parts and such that are great for small projects like this. I just wish I had seen this instructable before building my tool cabinet (photo attached).
    patricksworkshopHobbyJim
    Reply 3 years ago
    wow your cabinet is awesome ,looks like we both have a few chisels lol
    thanks for checking in
