The Making of a Powerful Low Cost Coilgun Which Is Portable
51,390
58
44
In this intructable i will show you how i made my coilgun, I will first thank, steaveastrouk, re-design, lemonie, orksecurity and others who helped me with my questions.  I became quite interested with this coilguns from the videos that was featured on hacked gadgets and intructable. So i decided to make my own research to understand how it works. After months of research i decided to go to the practice session.
 Comment PLEASE
Step 1: Parts List
Well for the design use you imagination because the parts that i used for the casing will be very difficult to find because they are all from a dismantled photocopier. Therefore for the electronics you will need some parts that is easily available on market or by salvaging them
Parts
  400V Electrolytic Capacitors. The more capacitance the better it will be. say like over 2000uf or more (Free)
 1k 10W resistors X 2(Rs20)
 BD243C or 2N6121 transistor or equivalent X2(Rs64)
 A centre tapped transformer on primary. we will come to that later on(free)
 A power supply that is rectified mains, car battery, or other batteries, in my case i used 10 AA 1.2V NI-CD batteries (12v in series)  (free)
 Some very very high current switches or relays(free)
 Full Bridge Rectifier 400V 3A or more to be on the safe side X 2 (free, salvaged from TVs)
 A 100W bulb(Rs21)
 Lots of wires(Free)
 Aluminium Tubing(R75)
 Enamel coated wire, i used the 1.2mm wire that i got from a tv.(free),, u can also use bigger wire for more current
2 Medium Heat sinks
Step 2: Tools and Other Materials You Will Need
Tools
Hot melt glue gun
Soldering iron
Grinder
Jigsaw
Wire cutter and wire stripper
Pencil for marking...............
Drilling machine
 Useful goodies
Metal sheefs and a food container(plastic) of appropriate size for the casing and  insulation
Duct tape or electrical tape
Solder the 2mm one
Flux (optional if your solder is not of too good quality)
Wood
Card Board
Battery holder
  Probably most important is a place to work. i conquered my mother's kitchen a few years ago and made it my workshop
Step 3: The Capacitor Bank
Find the maximum number of 400v electrolytic capacitors and connect them in parallel.
My capacitor bank ended up having a capacitance of 3475uF
 If you have 200v ones. connect them in series to give 400v and then in parallel to increase capacitance.
Make sure you use very thick wires because it will be driving current up to 350A.
Beware of polarities, it can result in a big capacitor explosion
you can probably use different capacitor values, but it would mess with the pulse time and it would not work nearly as well as it would if you used, say, all 120 uF 330V capacitors. The different uF values mean that each capacitor will have a different discharge pulse time, so if you graphed the charge put out over time the line would be all squiggly and not like the ideal curve that a uniform bank would have. In a worst case scenario the coilgiun might end up shooting the projectile backward, but I don't think that that could actually happen. It probably will just shoot it really slow.
therefore i recommend you to use close values of capacitance of each capacitor. Mine is really messed up, but i am fairly satisfied with it's performance
Step 4: Making Your Coil
Well not much to say, Google is here
I used 2 wires for one coil to decrease the resistance.
 i attached a tube to my drill and started winding the coil
 Here are the two coils I've made
 Note that if you use high voltage of about 1KV or more you can use thinner wires with more turn,
if you use low voltage, thicker wire will be needed,
I= V/R
Step 5: Getting Started With the Capacitor Charger
I've seen a lot of people using disposable cameras capacitor charger for their gun. The disadvantages of it are
1. Takes about 5min to charge a big capacitor bank due to its small size, it won't carry current needed for good charging time
2. Combining chargers are good but will not last long and the cameras here in Mauritius are difficult to find
3. Disposable camera means one time use, therefore it will work for a limited amount of time
 I designed my own charger using combining mains supply and battery supply.
  feel free to modify the schematic if you want. It is a simple push pull driver.
Charging time with my charger
3s from mains section
7s from battery secton
1s with 2 methods combined
Step 6: Packing Em in One
connect everything according to schematic below and you are done.
Relays allow more current to pass through them than regular push button switches, which normally weld together and then gets damaged.YOU can replace the relay with other devices like a thyristor or a big momentary switch.I found it best to use a relay because it switches very quickly and therefore last longer than other normal switches. most of the time the switches are damaged at the internal contact leads.
i leave the casing development on you because parts are too uneven to find or make as is
 I will put other videos of it later on.
Total cost of Project: RS200(about $7)
Future developments
1. Make it more powerful using more capacitors,
2. Using a more efficient coil.
3. Try to use my 600A 1200V thyristor( this is so heavy
3. Reduce the charging time from mains to 1s
6. Place a laser pointer.
7. Design a semi automatic reload system.(  just like the one that was featured on hacked-gadgets
Comment PLEASE
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    44 Discussions
    ARJOONNick_Tesla
    Reply 6 years ago on Step 6
    hnnnm the measured speed depends on the mass and length of the projectile,
    using sensors it is estimated to shoot about 150-250m/s on a full charge
    and the effective range i don't know
    robbertl1ARJOON
    Reply 2 years ago
    not even close, considered a very poor setup with way to less UF capacitance and a single stage. you may be glad to get 15m/s.
    im not even talking about the eddy currents due to the alluminium tube.
    my coilgun is still in design stage. with one coil running i achieve 20m/s with a 1500A thyristor and 4500uf charged to 450v.
    so about 200 m/s with this setup is total b*llsh*t :)
    big, powerfull and high end (multistage) coilguns manage to shoot 180m/s max!
    hey I'm starting a new project making a dual stage coil gun would a 7 x 29mm soft iron bullet be too heavy for copper coils?
    neil137
    3 years ago on Introduction
    sorry im not sure how to ask questions on this site but it seems to be the place with people in the know.
    i have several thousand dollars and a few months on my hands. i want a railgun. i dont mean the weak ones everyone else has. i want one that
    rivals a rifle in speed and could do some seriious damage. could anyone point me to what parts to order from online?
    or any tips to wiring and assembly? i have friends with cnc equipment and plenty of spare metal so it's not an issue, i just need some basic instructions
    on how to get started and what speeds would be possible. if i have to incoporate a backpack too that's fine. i just want to put solid proof out there
    that it's possible with todays tech. thank you.
    BruhklenHneil137
    Reply 3 years ago
    if you're asking this question you clearly don't have the technical know how to take on a project like that safely, start small and figure it out your self
    babutxt
    4 years ago on Introduction
    Can this coilgun will be able to fire a 50gram projectile
    " A centre tapped transformer on primary. we will come to that later on(free)"
    what does it mean?
    explain about it to me please
    found in old phone chargers. where the secondary is centre tapped. Here we use the secondary as the primary since we need to get from low voltage to high voltage.
    sorry for late reply
    Arjoon
    it's a Ni-Cd battery (Nickel–cadmium battery). i used 10 in series 1.2V each resulting in 12V.
    any other 12v power source is OK,
    you can even use a computer powersupply if you want to sacrifice mobility
    or use 2 6V SLA batteries/
    you have the choice
    i know how to make fully automatic design. but still this is a HYPOTHETICAL design.i dunno if this works. if u want to know arjoon then mail me at: bhadani.kahan@yahoo.in
    makdef
    5 years ago on Step 6
    I got impressed. not so elegant. but very clever this project. I am with a project like this. but Smaller. and I don't know, but the following tip maybe would help you: you can use more of one charger circuit. In my case, I'm using joulethief with secondary coil. so for me its's easier to have more of one circuit charger. and you must to use diode on the outs of each circuit to do not cause problems. and after the diode you can join them according with the polarity.
