Three Ways to Make a Wooden Chain
152,774
475
53
About: I got an old sewing machine when I was just a kid, and I've been hooked on making stuff ever since. My name is Sam and I'm a community manager here at Instructables.
Making a wooden chain is a classic wood carving project.
It is traditionally done using simple carving tools to make an unbroken chain from one solid piece of wood.
I thought it would be fun to explore different ways to make wooden chains using both hand carving tools as well as power tools. This is essentially a 3-for-1 instructable, covering three different methods I used to make some wooden chains.
Thanks for taking a look!
Step 1: Chain #1: Five Links From Basswood
This first chain has 5 unbroken links made from one solid piece of basswood.
Basswood is the most popular wood for hand carving because it is relatively soft and has a very consistent grain.
This chain was mostly hand-carved, although I made the initial rough cuts using a table saw and a scroll saw. Each link on this chain is 3 1/2 inches long, and 2 inches wide.
Step 2: Wood Blank
I began this chain with a 2" by 2" piece of basswood that was 10 inches long.
I marked lines along the length to indicate the middle 1/2 inch on all four sides.
The four long corners were then removed using a table saw. You could whittle away these portions by hand if you wanted, but that wastes a lot of usable wood.
The goal is to create a wooden blank with a "plus sign" cross-section.
Step 3: Template
I made a simple template for laying out the links on this chain.
This pattern can be easily duplicated for any size of stock material you may be working with. All you need to know is the width of your squared-up wood blank. In my case, it is 2 inches.
The template is made by creating a 4 x 8 grid on a sheet of paper, where 4 blocks match the total width of your square stock (so for me, each square is 1/2" by 1/2").
With a 4 x 8 piece of paper cut out, I folded it in half and in half again as needed to create the internal grid lines.
I then drew out the link pattern as shown in the photo. The actual link is 4 blocks by 7, and the remaining column of blocks (on the left in my photo) is used to indicate where to mark for the correct spacing between links when tracing the template onto the wood.
Step 4: Trim Template
To use the template, the middle 1/2" needs to be removed so it matches the "plus sign" wood blank.
To do this simply cut through the middle of the blocks indicated in photo 1.
The completed template is shown in photo 2.
Step 5: Trace Template Onto Wood Blank
The template can now be used to draw out the links on the wood.
Note the arrows on the template in photo 1. These indicate the placement of the pattern for the perpendicular through-link as shown in photo 2.
Use the template to mark all sides of the wood, being sure to line up things as closely as possible.
Step 6: Roughing Out
I was initially going to carve out these areas by hand. But I decided to cheat and just use my scroll saw to speed things up.
This is a little tricky, as the surface in contact with the table is only 1/2" wide. But it can reasonable be done if you keep the wood firmly pressed against the table.
Step 7: Rough Chain Shape
The rough chain shape is completed, but time-wise this is probably less than 1/4 of the way done with the chain.
All the fun and time-consuming steps lie ahead.
Step 8: The Challenge
Here is the challenge with any attempt at creating an unbroken chain of wooden links.
The area connecting adjacent links is marked in black in these photos. This areas needs to be separated in some way in order to proceed.
So think about it for a minute, just for fun. How would you do this? And what kind of tools do you think would work?
I tried a number of approaches to severing this connection, and some worked much better than others. Details on the other methods I used will be shown in later steps.
For this particular chain, I carved out these areas one little nibble at a time using a small carving gouge.
Step 9: Solution
I have a set of Flexcut carving gouges that I recently bought and have been experimenting with. It's a pretty popular starter set available on amazon. (This is the set I have: Flexcut carving kit)
For this step I used an 1/8" gouge (technically, it's called a "1/8 inch No. 11 veiner") to remove little bits of wood from between the connected links from every angle possible.
This is time consuming, but as you go, you learn which angles and movements seem to cut through the wood fibers most effectively.
My advice is to try different things, and when something seems to work, keep doing it. There's a lot of trial and error involved with learning skills like woodcarving, and I'm too much of a novice to attempt to teach much more about it than that.
Step 10: Keep at It
Keep nibbling away from all sides until you see a just a small strand of wood remaining.
At this point, you can give the links a gentle bend and . . .
Step 11: Snap!
If the pieces break apart with just a little bit of pressure, you're done!
Now repeat this same procedure for all the remaining links.
Step 12: Clean Up the Severed Areas
I used a 3/8" gouge to clean up the severed areas and remove the few splintery bits.
Step 13: Start Whittling
With all the links free from each other, the last step is to whittle down each link into a roundish link-like shape.
I used a basic carving knife for this step. It's important to take your time and enjoy the process--trying to rush something like this is not advisable. Strop your knife frequently and keep it sharp.
Chain #1 is done!
Step 14: Chain #2: 20 Links From a 2 by 4
This chain is made from 20 unbroken links made from a solid piece of a standard framing stud, or "2 by 4."
I tried to complete this chain using only power tools, to see if I could make a longer chain in less time.
Once I had established a method that worked, it was indeed a fairly quick process overall. However, in the end I found certain steps to still be quicker with my carving knife.
Step 15: Rough Out 2 by 4
To make the "plus sign" wood blank, I began by cutting a 1 1/2" by 1 1/2" piece of 2 by 4 using my circular saw with its edge guide.
With the edge guide and blade depth adjusted accordingly, I then cut off the four long corners of the blank.
Step 16: Lay Out Pattern
I made a pattern similar to what was done for the first chain, but this time laid it out onto cardstock, repeating the template a few times.
This template was cut out with a hobby knife, and then used to transfer the pattern onto the piece of 2 by 4.
Step 17: Build a Holding Jig
I built a simple holding jig out of a single 2 by 4 to hold the chain blank while I worked on it. Measurements and details are shared in the photo notes.
Step 18: Plunge Cuts
I started hacking down the blank into rough link sections with plunge cuts made with an oscillating multi-tool.
These tools are excellent for various home repairs and such, and a perfect way to make the plunging through-cuts needed in this situation.
After a bit of research, I opted for the Dremel version which I got for 69 bucks on amazon. Here's the kit I got. It's solid, and I abused the hell out of it while making this chain. Definitely recommend, if you're looking for one.
Harbor Freight has a cheap-o version for less than 20, but I try to gauge my HF purchases carefully. In this case, it looked like more of a potential hassle to go the cheap route. That said . . . Harbor Freight was the only place I could find that carried the 3/8" plunge cutting blades I needed for this project at a decent price. I picked up one of these blades, which was an absolute necessity for completing this particular chain. Here is the blade I got.
Step 19: The Challenge Revisited
Recall Step 8 from the first wooden chain, regarding the question of how to separate the individual links. That's where we're at again.
However, because this chain was being made with a 1 1/2" piece of wood rather than a 2" piece (smaller area to work with), and because this was splintery pine rather than that heavenly-soft basswood . . . this step proved much more difficult this time around.
My first solution was to carefully drill out the conjoining area with a small drill bit. I tried this approach on several links, and it actually worked on a couple of them. However, for the few links I successfully separated without splitting the delicate pine, the results were quite messy and overall just too inconsistent for me.
So I scratched this approach.
Step 20: Solution
Next I tried using the 3/8" plunge cutting blade with the multi-tool, and this worked marginally well. However, doing this nearly severs the sides of the links in the process. They're still intact, but not by much.
The best option I found was to use a multi-purpose cutting bit in my rotary tool (this is the rotary tool I've had for years, and love it).
This cutting bit looks similar to a regular drill bit, but is intended for cutting sideways like a router bit.
To separate the chain links, I would make an initial plunge cut like a normal drill bit from each of the four corners. Then from each corner I would pivot the bit up and down to nibble away the wood between the two links.
The secret is to not enlarge the entry holes as much as is possible, as this will eat into the links. Several of mine were quite sloppy, but after about 10 links or so I started to get the hang of it. It worked surprisingly well!
Step 21: Failures
This is quite a pile of failures, but I eventually found a way that worked!
Step 22: Cleaning Up the Links
I made 20 connected, unbroken links out of this piece of 2x4.
For the first 10, I used my power carving tool (this is the kit I have) and my basic rotary tool to clean up the links. This actually proved more time-consuming than using a carving knife, so I finish-carved the remaining 10 links by hand.
Chain #2 is done!
Step 23: Chain #3: 10 Links in a Ring From a 2 by 4
This third chain was made from 10 links cut from piece of 2 by 4.
This was the quickest and easiest approach BY FAR.
The secret is to make the individual links separately, break half of them into two, and then glue the broken ones back together linking up the unbroken ones in every other spot.
The net result is essentially the same, but you can produce a longer chain faster, and with cleaner-looking results.
However, since it's not made from one solid piece of wood, you lose all those imaginary coolness points in the process!
So it's a toss up, I guess. Read on to see how this was made.
Step 24: Pattern
I began by cutting a few 1/2" thick, 1 1/2" wide slats from a 2 by 4, and made a simple link template out of paper.
I traced this pattern onto the slats and marked hole centers on either end of each piece.
Step 25: Remove Middle Sections
I used a drill press with a 3/4" forstner bit to drill holes through each end of the links.
To keep the holes from blowing out on the bottom side, only drill down until the pilot point of the bit just barely breaks through the bottom side. Then flip over the wood and complete the hole.
Next I used the scroll saw to complete internal holes. Then I cut out the individual links.
Step 26: Sand Links
I used my bench sander to sand the outside of the links round, and my rotary tool with a sanding drum to sand the inside edges.
Step 27: Break Links
Half of the links were now broken in two. I did this by clamping them in a vice and gently tapping them with a mallet.
Just be sure to keep the mating pieces next to each other so they don't get mixed up. When these are glued back together, if you have lined them up precisely you cannot see the seam at all.
Step 28: Make a Chain
Using a bit of wood glue, I fastened the broken links back together with solid unbroken links between each glued link.
A 10-inch piece of masking tape is wrapped around the glued links as a quick clamp to hold the pieces together till they are dry.
When the glue was dry, I removed the tape and lightly sanded the glue joints until any visible glue and any trace of the seams were gone.
Step 29: Thanks for Reading!
There are undoubtedly many ways to make wooden chains.
These were just the methods I tried. Do you know of another method you've seen or tried yourself? Let me know in the comments!
4 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
53 Discussions
attosa
11 months ago
This is so good it hurts my head.
rbeforee
1 year ago
Now I want to puzzle out a way to make the closed loop on chain links without breaking them. Keeping with the grain is the challenge. I suppose I could work it out if I was willing to have some run across the grain. Perhaps circular links?
This is an excellent Instructable. I tried a chain years ago, but broke a link and became sullen. LOL I did manage to carve a pair of connected padlocks though.
rbeforeerbeforee
Reply 1 year ago
I had to sand away some blood though LOL You all be careful out there. Consider getting leather finger cots, or at least have regular finger cots on hand to prevent leaking and clean wounds clean.
Milesguy
1 year ago
Neat!! very helpful. I made a chain before, but I made round links.
Looks a lot easier to use oval ones. I'll have to try oval ones sometime.
GerardZ1
2 years ago
Nice instructable...well presented....
MGriffies
2 years ago
Steve Ramsey has a Youtube tutorial on making chains using a router! Look him up and his way just eliminates any sanding or carving! His link is as following: https://www.youtube.com/watch?v=1pHCfXtRYCA
seamstermakendo
Reply 2 years ago
Oh nice! I had not seen that yet, thanks for the link.
I love that he went back to a roughing knife at the end, just like I did with my 2nd chain above. All power tools proves too slow. Ha!
Ehlers_TV
3 years ago
AWESOME !!!! I need to TRY !!!
DeeRilee
3 years ago
My grandmother had a wooden chain that my father had made as a teen...at one end of it was a wooden "cage" with a ball inside...all from one piece of wood. I was always so fascinated with it!
Love this project.
seamsterDeeRilee
Reply 3 years ago
Thank you! I've been looking for another carving project to start. Perhaps I'll have to make a caged ball next! :)
amberrayh
3 years ago
Awesome project! Thanks for sharing. Beautiful pics and write up as always :)
seamsteramberrayh
Reply 3 years ago
Hey, hey! Thank you. Nice to see you still poking around here! :)
blackbeard52
3 years ago
Use a Power carver trick to hold set 1 level for cutting. replace the blocks removed with plus sign cutouts insert the gap with matchsticks and tape the block back in. this will make it safe to cut since it will now be 2 inche base
fdc313
3 years ago
I really like the ring link, even if it is cheating :) .. Great tutorial
seamsterfdc313
Reply 3 years ago
Thank you, I really appreciate it.
BillK39
3 years ago
LOL!!! #3 looks to be cheating to me! I wouldn't tell though!
seamsterBillK39
Reply 3 years ago
Ha! Yep, it's definitely "cheating" if you're a carving purist :)
I certainly value the unbroken (mostly) hand-carved one the most, so that says something!
Attmos
3 years ago
Very cool, I like it. Thanks, this is really inspirational.
seamsterAttmos
Reply 3 years ago
Thank you for the compliments! I hope you'll make some. Be sure to share a photo if you do :)
