Tito - Arduino UNO 3d Printed Robot
21,452
101
17
About: Industrial Designer, maker of toys, robots and consumer products with remarkable initiative to explore solutions in multiple areas with lateral thinking, together with engineering, 3D creation skills, hands ...
Tito is a Biped dancing DIY robot, derivative from Zowi and Bob, basically has been adapted to an standard Arduino UNO board with easier connections and supports. It was the first iteration for Otto DIY (www.ottodiy.com)
Step 1: Tools & Materials
Arduino UNO board or compatible (in my case a DFRduino UNO)
Nano breadboard
Buzzer
Futaba servo S3003 x4
HC-SR04 Ultrasound sensor
Powerbank (optional)
Nut M3 x20
Screw M3 x20
3D printed Head
3D printed Base
3D printed Leg x2
3D printed Foot R
3D printed Foot L
Tools: 3D printer, allen key and screwdriver
Step 2: 3D Print Parts
3D .stl files here: http://www.thingiverse.com/thing:1378605 Find a way to 3d print the parts, they are designed for no supports so is very easy to print with 20% infill and 0.2mm resolution.
Since is Tito is completely opensource you can find the design 3d model files made in Autodesk 123D Design here:
Step 3: ​Pre Assemble
There is many was to build Tito, but one recommendation is before the connect the servos is to assemble the servo disk pieces to the legs, then put the servos in the body and the feet..
Step 4: The Schematic
Follow the picture for the connections. HC-SR04 Ultrasound sensor (trig for pin 8 and echo for pin 9). During the making process you may need to disconnect and connect constantly so just keep this schematic present for further fixes.
Step 5: ​Test the Position of the Servos
In the picture the cables are disconnected but the idea here is to upload a code to the Arduino UNO board that will put the all servos in 90 degrees and then match the right angle for the crank discs in the body and the feet. Tito should be in a position like the photo. then you can fix all the servos with the screw axis.
Step 6: ​Assemble Arduino UNO Board
This design make it easy to fix any Arduino Uno compatible board (in my case a DFRduino UNO) in the head part, you can use up to 4 screws.
Step 7: ​Final Assembly
If all connections are secured you can close the head part and fix it to the body using the lateral screws.
Step 8: Arduino IDE ​Programming
All libraries and sketch codes are in this Github repository. Just connect your USB cable to Arduino UNO and upload the codes There are many programmed movements for the robot like walk different directions, ultrasound, raise, tilt and dance.
Design Now: 3D Design Contest 2016
Runner Up in the
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
17 Discussions
Carmapia
Question 4 months ago on Introduction
Hello! I'm printing several Tito robots for my students. I want it to be their final project. But we have a problem: in my school we only have the micro servos. Is there any way to do the assembly with these? Could we adapt it in some way? Could you explain me, please? Thank you!
1 answer
CarmapiaCarmapia
Answer 4 months ago
And other question: is it possible to program It with Snap4Arduino??? We are working with this program. Thanks!
FrankyH2
1 year ago
Hy
ich have allready printed the design and i have alle wires connected correctly, but when i upload a Code the Otto makes not that was he made. the left Servo was permanently 360 !!!! and the other makes not.Can you help me please ?
cparrapaFrankyH2
Reply 11 months ago
Hi Frank
you must use 180 servos otherwise how to align? i don't have experience with 360 but probably they need some special calibration.
babu.garg.2004
Question 11 months ago
I am not able to find the code can you please send me the link .
cparrapaxinxibiri
Reply 2 years ago
you are welcome man, have you build one of them?
katiaflcparrapa
Reply 1 year ago
Thank you for sharing the work! I'm making a kit for students to ride (I'm from Brazil). doubt about energy. You used Powerbank 5V?
PS: sorry, i used goggle translator.
cparrapakatiafl
Reply 1 year ago
Hi Katiafl
join the Otto builders group in Facebook !(https://www.facebook.com/groups/ottodiy/) there are many Brazilians there they will help you in Portuguese! ;)
Best Regards
Camilo
jmook1
1 year ago
I did everything correctly but i am getting a message that says error opening zip file. I was wondering if you have any ideas?
jmook1
1 year ago
Hello, I have one question. Could you post the code using software. I am having a little trouble downloading the code and I am certain that it is because the code was written with a PC. If not i might need a little help to download the code.
cparrapajmook1
Reply 1 year ago
Hi the code require the libraries so you need to download the whole packgage go to ottodiy.com built it! section and clic in the donwload button
Oh Jonathan
1 year ago
Hi, I am currently trying to make one, but the servos did not come with those disks for the feet. Any idea where I could get them?
cparrapaOh Jonathan
Reply 1 year ago
Go to hobby stores or makerspaces they should have a lot of them
Starswap
2 years ago
I might try and make this but i was just wondering if you could tell me where you got your motors from because i'm new to this sort of thing and don't really know a good price. Thanks!
cparrapaStarswap
Reply 1 year ago
Hi i bought them in China so i don't know a good price outside maybe mamazon. https://www.amazon.com/Futaba-FUTM0031-S3003-Standard-Servo/dp/B0015H2V72
