Toy Box/hope Chest
4,134
102
4
Introduction: Toy Box/hope Chest
About: i love to try and build new things
Here is the story of my first hope chest build. I have never built a hope chest before but if i can do it so can you.
Step 1: Material and Tools
I built this Toy box with oak wood.
  • oak 3 1x4x8
  • 1 2x4 sheet of 1/2" oak plywood
  • 2 2x4 sheets of 1/4" oak plywood
  • glue
  • poly/stain of your chose
  • kreg screws fine thread
  • piano hinge
  • safety hinges
tools
  • Router
  • table saw
  • router table
  • chopsaw
  • drill
  • kreg jig
  • clamps
  • sander
Step 2: Cut the Wood to Length!
Cut list
4 at 15 inch for the legs i put decorative curve at the bottom.
4 2 " wide by 15" long for the sides
4 2" wide by 36" long
good time to sand everything down be for putting it together.
Step 3: Pocket Hole
drill pocket holes on the 4 side pieces and the 4 36" pieces.
Step 4: Dry Fit Assemble
at this point i wanted get the measurements to make this as easy as possible. so i did a dry fit assemble
i made sure the the opening gap was 11 1/2
at this point i marked out where the inside routed edge would be to inset the 1/4 ply wood.
I planned on putting in a 12 inch piece of 1/4 plywood
Step 5: Router Time
Get creative use the router with different bits have fun ! used the 1/4 inch bit for the plywood inlays i used the router table for this.
i then used the router with a decorative edge to route the outside of the box
Step 6: Glue and Reassemble
glue all the joints and screw this together not a bad idea to sand everything down at this point before adding the plywood.
Step 7: Add the Plywood
this is why I said make sure the opening is 11 1/2 1 2x4 sheet will do the front and back an the second will finish the sides
Step 8: Add the Top
I cut this the same size at the top and added 1/2 in strips of solid oak to cover up the edge of the plywood this gave a nice edge all the way around the box and a nice lip for opening the box i added a piano hinge in the back with 2 safety hinges to save any fingers.
Step 9: Bottom
I added 4 strips of wood to the bottom and laid a 3/4 inch piece of plywood. I am 210 and was able to stand in this without it breaking!
Step 10: Make It Personal
I then printed off the name of the future owner using a lazer jet printer place some polyurethane on the box and put the name on rubbing out any air bubbles aloud 2 hrs to dry and then soak it with water and rubbed away the paper leaving the name.
Step 11: Stain
I used a poly stain blend and was pleased with the result!
Hope you enjoyed this tutorial as much as i did making it!
    • Fix It! Contest
      Fix It! Contest
    • Water Contest
      Water Contest
    • Metalworking Contest
    4 Discussions
    It is quite lovely, I wish my dad had been able to make me one, when I was a kid. I like the rounded edges on the legs. But serious issue, no air holes for when the tot falls in and suffocates? I think it makes them ugly and negates them for use a wedding/hope chest, (they don't seal), it is for a kid.
    One like you, talented, (I am afeared of table saws), could make a thin panel that is movable made of thin cedar (for closets), that could cover it when the kid is bigger and it becomes a "hope" chest.mount it against the front or underneath when the kid is a kid, then put in blocking position when the kid is bigger and future goodies are loaded in.
    I'll poke holes in the top and put grass and water in it!! No seriously the 2 safety hinges make it so the lid wont shut, and with little pressure will open up. i thought about adding cedar but ran out of time this was for a 2 year old birthday Girl. thanks for checking it out
    That looks really nice. Congratulations on such a nice product, and thank you for sharing it.
