Translucents Hollow Beads- Necklace
5,720
340
17
Sharing one way to create the molds for the liquid fimo hollow beads.
How to apply color and make them translucent
Supplies:
Step 1:
Materials used in this poject:
- Water
- Soft natural clay (potters clay)
- Silk stocking
- Cotton
- Toothpick
- Alcohol
- Alcohol markers
epoxy glue
- head pin
- bead cap
- chain
Step 2: Making the Mold
Mix water and soft natural clay to obtain a creamy liquid: Barbotine (ceramic slip)
Using a silk stocking and cotton make the bead mold
Dip the mold in the barbotine and let it dry.
It can air dry in a few hours, or in a few minutes if you use the heat gun.
Step 3: Liquid Polymer Clay Bead and Color
Once dry, cover the mold with a thin layer of liquid fimo and apply heat starting on the top
Apply a second coat and dry it again with the heat gun.
Apply color using alcohol markers and alcohol to obtain the translucent effect.
Make a new layer of liquid fimo and cure it. After that you can add a few more details with color.
Finish the piece with two more coats of liquid polymer clay.
Is important to work in a well-ventilated place.
By using the heat gun Fimo Liquid can release fumes
Step 4: Removing the Mold
Remove the toothpick and cut the silk stocking
Start removing the cotton from the inside. In this first phase don't remove the silk stocking, because it will be stuck to the barbotine To remove the barbotine and the silk stocking, dip the bead in warm water
Step 5: Finishing
You can put water inside the bead to create a more interesting effect (Optional)
Make the top for the bead with a small amount of liquid fimo (2 layers). Make a hole in the center and insert a head pin.
Glue it to the bead using epoxy glue.
Cover the top using a bead cap and mount your necklace.
Step 6: Have Fun!
Create new molds with different shapes and make more necklaces!! :D
Necklace Challenge
Runner Up in the
Necklace Challenge
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    • Arduino Contest 2019
    17 Discussions
    mom7478
    2 years ago
    WOW! What can I say.....
    Bella99
    3 years ago
    This is absolutely beautiful, can't wait to try it out^^
    Shay1001
    3 years ago
    What is liguid fimo
    terriilyn
    4 years ago on Introduction
    really beautiful. so creative. you have more patience than I possess, clearly.lol
    What a great idea.
    Have you experimented with including LED lights?
    Your experimentation reminds me of Tiffany glass in the Haworth Art Gallery in Accrington.
    The work there took on a whole new life when illumination was included. It went from mind blowingly awesome to something that's so amazing it doesn't seem real.
    sandrartes
    Hi Snowflakepixie77! :D
    Thank you for your nice comment! :D
    Yes it's possible to make them with any color. I like the idea of the acorn cap. I have a few acorn caps... I'll try one. I'm sure that it will look very cool :D
    Thank you for the suggestion!!
    traeger
    4 years ago
    Creative technique and very pretty necklaces!
