Tuning a Hand Plane
42,371
504
33
About: Happy in wood shavings YouTube: http://www.youtube.com/c/WOmadeOD Patreon: https://www.patreon.com/WOmadeOD
The No.5 'Jack' hand plane can be used for a number of tasks (scrubbing, dimensioning, shooting, and smoothing, to name four) but to perform really well at all of these, most planes will need a little tuning. Here I've tuned two jacks to add to my original, allowing me to leave the set up differently in each one. However, you can tune one plane to tackle all jobs, and just keep differently shaped blades to swap in as necessary.
Most of the tips and processes here, can be used with other hand planes, perhaps focusing on the specific task(s) you want to use them for.
I hope you find it useful.
I'm entering this in the 'Before and After' contest, so I'd appreciate your support - thanks, Mitch
Supplies:
Step 1: Here's the Video
If you prefer video, then take a look at my YouTube video, which runs for 31 minutes. If you find it useful, then please like, comment, and share.
Step 2: Lets Clean Everything to Begin With
Badly rusted planes can be soaked in white vinegar for a couple of days, which will loosen much of the rust and debris.
Strip down the plane, using WD40 for seized threads.
Use a stiff brush to remove all loose dirt.
Glue and paint are often spilt on planes (?) and can be scraped off with a card scraper, etc.
Small parts can be soaked in paraffin (kerosene).
(If the original Japaning (paint) is in a bad way, you may wish to strip it, or abrade it, and apply a new coat at this point - But that's restoration rather than tuning )
Step 3: Fit the Frog - Part 1
To avoid buckling of the plane body, and to ensure solid working, the frog should be well fitted to the body. Smooth, flat mating surfaces are best, and can be achieved by working the milled 'pads' on a flat reference surface with 180/240 grit abrasive paper.
Step 4: Fit the Frog - Part 2
Attach the blade set, to limit forward travel, and note frog's most forward position - there's no point doing more work than you need to!
Use a permanent marker, or engineer's blue, to mark the pads on the body.
Replace frog and move it around to mark the 'high' spots of the body pads (the marker will be removed).
These high spots need to be taken down, for which a scraper made from an old file is ideal.
Scrap the high spots, and then repeat the process of checking.
Continue until you have a large area of contact on every pad.
Step 5: Frog Face
A flat, smooth, frog face makes the best bed for the iron.
Unless the face is substantially out of flat, I leave the blade adjusters attached and flatten around them.
(In extreme cases, these can be removed: The lateral adjuster will need it's rivet filed down and removed, whilst the depth adjuster will need it's hinge pin driven out.)
Work the face evenly on a flat reference with abrasive. You can use permanent marker to see where you are abrading, and a straight edge to judge when the whole surface is flat.
Step 6: Check the Squareness & Flatness of the Sole & Sides
Use an engineer's try-square to check the squareness of the sides to the sole, and a straight edge to check the flatness of the sole. This should give an idea of where metal should be removed.
Use a marker to note these indications on the body.
Step 7: Flatten the Sole
With even pressure, work the sole over some coarse abrasive on a flat reference.
Your initial indications should begin to fade, and you should judge whether you're applying the pressure evenly.
Mark lines right across the sole, and continue to abrade until all lines begin to fade evenly.
At this stage the sole should be flat, but rough.
Step 8: Square the Sides
Re-check squareness of the sides to the flattened sole.
Now judge and remove the metal required (just from the sides) to bring each side into square with the sole.
Working once again with abrasive and a flat reference surface, square the sides, by applying pressure more on either the sole edge or wing tip, depending on where you need to remove metal.
Larger discrepancies can be tackled initially with a mill file.
Step 9: Polish the Sole
The flattened sole can be polished using finer grits of abrasive, and metal polish with '0000' steel wool.
If you take care to only just remove the flattening score marks across the entire sole, then the flatness should remain.
I take this up to a semi-gloss mirror polish, but feel free to continue as far as you want.
Step 10: Lever Cap
The underside tip of the lever cap should be perfectly flat and smooth, which can be achieved on the abrasive reference surface.
It's top surface will benefit from a polish with '0000' steel wool and metal polish.
Step 11: Replace the Iron & Chipbreaker ?
Where you can afford it, a replacement blade set, like this one from Hock Tools, will be a worthwhile investment.
Step 12: Iron/Blade
A sharp edge is formed at the meeting point of two polished surfaces - the back of the blade, and the tip of the bevel.
Grinding marks should be removed from the blade back. I'm using a diamond whetstone here, but other sharpening systems are fine. Keep the back flat on the stone at all times, and switch to a finer grit once the grinding marks have been replace by the diamond scratches.
Remove the grinding marks on the tip of the bevel. Freehand or with a guide is fine. For cambered blades, apply pressure selectively to cover the curve, and finish with a gradual transfer of pressure to smooth it out.
Both back and bevel should be stropped to a mirror finish at the edge.
Step 13: Chip Breaker
The tip of the chip breaker should mate tightly with the iron when attached.
First prepare the underside at the tip, so that the extreme tip touches the iron first, by hanging the tail lower than the stone as you work it. Continue to work until this area is flat, for contact right across the width.
Polish the top leading edge to prevent shavings from catching.
Check for the desired 'light free' fit.
Step 14: Increase Mouth Opening ?
If you require a wider mouth, perhaps if a replacement blade set closes it up too much, then scribe a line to work to and file back to it.
Maintain the same angle (usually 45 degrees).
Step 15: Slack in Blade Height Adjustment ?
If the spin wheel groove is too wide for the ends of the yoke, here are two possible solutions:
Malleable iron yoke - widen the engaging discs by carefully hammering them.
Alternatively - fill excess groove space with a circlip.
If the adjuster tongue is too narrow (or chip breaker slot too wide), you can pack the gap with a clip made from sheet metal.
There is no reason why you should end up with more than a half turn of slack.
Step 16: Mouth Clogging ?
To make a little more room for shavings, once they have entered the sole, it is a good idea to relieve the upper corner at the front of the mouth.
Just file carefully at an angle, ensuring you don't quite reach the underside of the sole. Finish by polishing this bevel.
Step 17: Handles
Why not take the opportunity to freshen up those rough handles.
Cracked and flaky finish can be stripped.
A good sanding to remove all sharp edges.
Then a gentle finish such as either oil or shellac applied.
Step 18: What Should You Expect?
A highly cambered iron will take thick cross grain shavings.
A straight iron will dimension wood and shoot end-grain easily.
A very slightly cambered iron will take whisper thin smoothing shavings.
Thanks for reading, and I hope you found this interesting.
Happy woodworking, Mitch
Before and After Contest 2016
Second Prize in the
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    33 Discussions
    blackpearlin
    1 year ago
    Very valuable information. Thanks for sharing!
    Diverjad
    1 year ago
    Awesome Video! Thanks for the attention to details. JD.
    DIY-2015
    2 years ago
    Can't thank you enough , complete tuning a hand plane , Thanks a lot .
    BossyRangs
    3 years ago
    Congrats on winning the second prize in the hand tool contest! You deserved it.
    BeachsideHank
    3 years ago
    Best just to live with any backlash in the blade adjuster knob, many a fine plane has been ruined by trying to bend the forks to reduce it, usually resulting in just breaking one of the fingers off. The lever cap's leading edge was used by the old timers to tighten or loosen the chip breaking cap iron adjuster screw, and as a rule of thumb the backset of the chip breaker iron from the cutting iron's edge was about 1/2 the thickness of the blade.
    WOmadeODBeachsideHank
    Reply 3 years ago
    Poor old lever caps - that's probably caused a few shavings to trap in the mouth :-)
    carlosglatzos
    3 years ago
    Great Instructable, good video, still watching, but just want to give the thumbs up! Cheers.
    SamM16
    3 years ago
    it would be nice to show how to sharpen the actual blade edge using something else other than sandpaper, like ceramic stones and liquid emulsifiers.
    WOmadeODSamM16
    Reply 3 years ago
    I used diamond plates here, and you can find other methods in my sharpening videos on YouTube. I'll try to find time to do some more sharpening specific instructables in the future.
    SamM16WOmadeOD
    Reply 3 years ago
    yeah woke up early one morning not too long ago the tv was on and got to watching a step by step sharpening of wood planes on PBS and the guy doing it was using a two step process & within a few minutes had that thing shaving wood so thin you could see through it. He used a circular method after applying some sort of white liquid to ceramic sharpening blocks and man oh man it was impressive...quick too.
    Tones Shed
    3 years ago
    Hi Mitch, Thanks for the video and detailed explanaitions, as a novice, your collective videos have helped me better understand the restoration, set up, use, and maintenance of a few different species of hand plane, from the stanley #45 to my number 5 1/2 and a few woodies also, the sweet ppfffsssstt as the blade slices that microthin waffer is a joy to behold.
    For those struggeling with your handplanes, perservere, there is not much out there that compares to a well tuned plane.
    Cheers, Tony
    alfie232
    3 years ago
    hi very useful and clear liked it very much
    geeser
    3 years ago
    Hi, thanks for the instructions. Can you please say what you mean by 'highly cambered', 'straight iron' and 'slightly cambered'? I do not understand these terms. thanks
    WOmadeODgeeser
    Reply 3 years ago
    Hi. These just relate to the amount of curvature of the blade edge. straight has no curve, and is used for shooting mainly (using the plane with a jig to accurately plane a component). slight camber has a very small amount of curvature, used for smoothing and general work. large camber is more pronounced curve of the edge and is used in scrub planing - the curve allowing thick shavings to be taken across the grain without tearout.
    hansdohm
    3 years ago
    I have some old planes and you've made want to go back at them and check for anything to improve them. Great Job! IMHO
    Post a comment
    BossyRangs
    3 years ago
    Hey Mitch, very clear explanation! You're very thorough, I'll give you that. You got my vote! I've learned to restore and tune a hand plane a couple months back thanks to your 2 hour video on youtube. Yes, I'm that 1 person who watched the entire video. Hahaha
