Turning an Old Pallet Into a Dog Bed
11,121
364
4
Supplies:
Step 1: Supplies
A pallet
Four-14 inch 4 by 4's
Two-41.5 inch 2 by 6's
One-48.5 inch 2 by 6
Two-31.75 inch 2 by 4's
One-39.25 inch 2 by 4
Two-46 & 1/8 inch 2 by 4's
A piece of carpet 36 by 40 inch or a dog bed
Tools needed: (the tools pictured above are what I originally planned to use but then used many more)
A drill
A driver
A hammer
A crowbar
A chisel
Various size screws
A circular saw
Step 2:
First pry off the top and bottom support board on the bottom. Then measure 4 inches in on the cross support and cut that off, do this to each corner.
Step 3:
Next draw a 4 inch by 4 inch square, do this to each corner and cut. Then use the chisel and clean out the corners.
Step 4:
Now measure 6 inches in and draw a line across all the 14 inch 4 by 4's. Line up the 6 inch line so that it lines up with the bottom support. Then put a 3 inch screw in diagonally to hold the 4 by 4 in place. Do this to each corner.
Step 5:
Next put the 46 & 1/8 inch 2 by 4 through the bottom. Then put the cross support you pried off in the beginning on and use 2 2 inch screws on each side. You then need 10 more 2 inch screws. Put 2 in each cross support in to the board you put through and put to into the 4 by 4. Then do this to the other side.
Step 6:
Now take the two 31.75 inch 2 by 4s and put them in between the shorter sides and put a 2 inch screw in sideways at each end. Then take the 39.25 inch board and put that in between the 4 by 4s on the back. Now put a 2 inch screw in sideways at each end.
Step 7:
Now you just have to put on the top boards. You are going to need the 48.5 inch board and the two 41.5 inch boards, the 2 by 6's. Now cut a 45 degree angle off on each side of the 48.5 inch board. Then cut a 45 degree angle of one side of each of the 41.5. Next position them on top and put 2, 2 inch screws in each board.
Step 8:
Then you are done, you can now add carpet or a dog bed!
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    4 Discussions
    fred3655
    4 years ago
    It's okay, not sure if it would be a hit with the lady dogs if Fido plans on entertaining. Just Kidding.
    seamster
    4 years ago on Introduction
    This turned out looking super sharp! Nicely done, I like it!
