Twinkling Christmas Tree Card
7,010
45
About: YuKonstruct is a non-profit society which provides an enthusiastic community of makers and entrepreneurs affordable access to space, equipment and knowledge. This community serves to embrace the individual a...
This project was created for YuKonstruct's Chibitronics Build Night and uses a Chibitronics effects sticker and three LED stickers.
The effect sticker has three pads: + and – for power and a signal pad that generates the pattern. The signal pad is pre-programmed to switch between + and -, which causes the lights connected to it to turn on and off.
YuKonstruct is the first makerspace in Canada's north. Our mission is to provide access to shared space, quality tools, available expertise, and a collaborative environment to help makers build anything!
For this card you'll need:
Step 1: Make the Circuit
Fold a piece of blue cardstock in half to make a card.
Using the circuit diagram as a guide, apply the copper tape and Chibitronics stickers to the front of the card. For the best results, fold copper tape to avoid tearing around corners.
Test to make sure the circuit works by placing a bit of copper tape over the + side of the battery and copper spiral before proceeding to the next steps.
Step 2: Add Tree and Snow
Glue the battery in place. Be careful to ensure it maintains contact with the copper tape.
Cut a Christmas tree out of green cardstock. Punch holes in the tree over the LEDs. Glue the tree to the front of the card with small craft foam pieces to keep it raised over the LEDs.
Cut a strip of cardstock the width of the card to be the ground below your Christmas tree. Apply a thick strip of copper tape to the back. Glue the edges of the ground piece to the front of the card.
Step 3: Decorate
Pinch together the ground strip and card front with a bobby pin or paper clip. The card can be turned on and off by sliding the clip back and forth.
Decorate the card as desired.
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    3 Discussions
    DonnaM48
    2 years ago
    Do you have to use a paper clip or a bobby pin? Is there a way a person can just press to see it light up? I was thinking of creating a card but not if i have to use a bobby pin. Any ideas? "thanks"!
    tomatoskins
    4 years ago on Introduction
    I've never used copper tape. It turned out great! I've always used conductive paint for applications like this in the past. Great stuff!
