UNO R3 2.8 TFT Touch Screen With SD Card Socket for Arduino Board Module
115,664
214
23
About: Will write code for food. :) If you need help with any of your embedded Arduino applications please send me a message.
Trying to get this touch screen display working has caused some people frustration. The unit came in an anti-static bag as shown in the pictures with a stylus and NO documentation. After searching around I found some libraries and arduino code that worked with this module. After some modifications I was able to execute a simple paint program, number pad, bitmap display (from SD), and a simple screen saver / calibration helper sketch that shows raw data; good for troubleshooting. Read the next steps to find out more information and view the source code examples.
Supplies:
Step 1: Get Connected
Connect your touchscreen shield to the arduino uno board as show in the pictures. There will be two pin slots open on each side.
You can download the number pad sketch along with all the needed libraries here:
https://github.com/dmainmon/myNumberPad
You need to unzip and extract the download then copy the contents of the libraries folder into the Arduino libaries folder: on windows usually it is in \documents\Arduino\libraries
Step 2: Screen Saver and Calibration Helper Sketch
Copy the code example in the demonstration video and upload the sample sketch to an Arduino Uno. This sketch allows you to touch the screen and get raw x, y and transposed x, y coordinates. The raw data is necessary to properly calibrate the touch screen. The sketch also demonstrates shifting states based on touching one of the onscreen buttons. Depending on the state, the program will display a different shape at the location of the touch. The program will also go into a screen saver mode that displays the current state shape.
Step 3: Bitmap Display for UNO R3 2.8 TFT Touch Screen
This sketch demonstrates the standard bitmap display from the SD Micro card inserted into the touch screen. The bitmap files first needed to be copied to the root folder of the SD card. You can do this using a computer. The files need to be named the same as those in the sketch, or you can change the sketch to reflect different file names. Watch the video to view the demonstration and source code.
Step 4: Paint Sample for UNO R3 2.8 TFT
This video demonstrates the standard AdaFruit paint program modified to work with UNO R3 2.8 TFT Touch Screen module.
Step 5: Touch Screen Numeric Pad Example
This video demonstrates a number pad sketch for the UNO R3 2.8 TFT Touch Screen Module. The original sketch had issues on this module. The numbers when touched were reversed on one axis; touching "1" would produce "3" and "4" would produce "6" and middle numbers like "2" and "5" were correct. This sketch fixes this problem by accurately transposing the raw x, y coordinates.
Step 6: Fix for Mirror Display Bug
I connected this module to my Arduino Mega 2560 and uploaded the sketch. When the number pad displayed, all the numbers were in the correct place but everything was mirrored! I uploaded my screen saver sketch and everything worked as expected, no mirroring. I uploaded the paint sketch and that worked as expected as well. So I examined the code and noticed the only difference with the number pad sketch was that the rotation was not set. The number pad uses the default rotation and this value was not set. So I added this to the setup function and everything looked normal.
So if you are using the Arduino Mega 2560, make sure you add the following line to the setup function: tft.setRotation(0);
Step 7: Moving Forward...
Moving forward with this display I decided to do another project graphing analog signals. The project uses two analog signals: one from a photo resistor and one from a mic / amp module.
If you are interested, take a look a the instructable https://www.instructables.com/id/Arduino-Analog-Sig...
Thanks!
2 People Made This Project!
  • Party Challenge
    Party Challenge
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
23 Discussions
brightled
10 months ago
Hello,please post our code also ..the screen driver must be known and that info must be known in order to get these things to work correctly..you show your code and then the vid blurs..Someone needs to write a pdf teaching how ,what ,when and why concerning these screens I would gladly pay $10.00 and I am sure others would too.I have 3 different tftlcds only 1 works its for the mega and Bomer has a lib for it,I am really considering use of Nextion units from now on 4 pins easy programming but higher cost...also the small cell phone screens use spi mode and are real easy to set up and use
kavehnwc
10 months ago
The program runs and nothing is displayed but a white screen. when I open the COM4 I see that when I hit the screen numbers appear to calibrate the screens position so it is registering but not showing up on the LCD. please help me before I pull all my hair out.
GaryG173
Question 1 year ago on Step 6
Is there any way, with an UNO, to add other I/O, given all the pins are used/covered, and none are brought through? I'd like to interface a 5-pin joystick. Is the only answer "buy a Mega"?
rosscameron_ca
1 year ago
This does not work - won't link:
undefined reference to `TouchScreen::TouchScreen(unsigned char, unsigned char, unsigned char, unsigned char, unsigned int)'
undefined reference to `TouchScreen::getPoint()'
LizN21
1 year ago
Where's my post?
I'm thinking I need an Arduino Mega to do what I want - a Universal Remote. Because after mounting the display there are NO pins left for anything else.
LizN21
1 year ago
This is so confusing...
And this is coming from someone with an Electronics & Programming background. I am shocked at the dearth of documentation and multiple libraries with multiple dates for this thing. And to find out that it might start out with a Mirror Image - WOW!
I find that Aidafruit has changed a lot since I was there years ago. It too is confusing and some links referenced there are no longer valid.
I am trying to make a truly Universal Remote Control out of this mess. I just got the Arduino Uno & the Display and put it together and there are NO pins left to operate an IR LED.
And just what is the CON1 on the Display Shield? Possibly a way to connect other devices/sensors...?
One thing I did discover is that this is a LGDP4535 clone. That number is mentioned in the sparse so-called users manual that came with the display.
I have downloaded all kinds of libraries suggested in various posts... again, WOW!
Maybe I won't have to take a hammer to it...
srivera18
2 years ago
There are no ino's for TFT and Aidafruits in the libraries. I'm a newbie to arduino, what am I missing? BTW, I did get the number pad to work.
mderton
2 years ago
Thank you for the instructable. I'v been trying to build a DIY smartphone but couldn't get the code or libraries for the touch screen. Now i can finally build it. Thanks.
mkeschmann
2 years ago
I'm having issues getting this display to work on my Arduino 101 board with the libraries that are suggested - errors in compiling seem to indicate that the board type isn't supported in the Adafruit_TFTLCD library. Here's a representative error:
" ...\Arduino\libraries\Adafruit_TFTLCD\pin_magic.h:350:3: error: #error "Board type unsupported / not recognized"
#error "Board type unsupported / not recognized" "
I'm expecting that I need to update pin_magic.h to include definitions that support the 101 board to to set the polarity of the data/control lines, but
feedback would be greatly appreciated. And if anyone has the updated file then gaining access to it would also be great!
Thanks, Mike
dmainmon
2 years ago
This video will show you how to fix the inverted display on the Mega
ChanghanJdmainmon
Reply 2 years ago
Thank you so much!
Now everything works perfect with my Mega!
Eric Brouwer
2 years ago
Thank you SO MUCH for posting this.
After 3 days of searching the internet, I was still unable to get the resistive touchscreen to work.
I finally got the touchscreen to work correct using your links to the libraries. Found out that this specific TFT display module uses pin 6 & 7 for touch sensor, instead of the standard 4 & 5.
siliconghost
3 years ago
Great overview of this great affordable screen. Can you attach your UNO sketches?
siliconghostsiliconghost
Reply 3 years ago
I never received a response on this, so went through the painful process of copying code from the video. It can be found here for others that might need it. Not that this has some minor changes, but is fully functional and I will continue to refine: https://github.com/siliconghost/Arduino_2.8in_TFT_wSD
Railessiliconghost
Reply 3 years ago
To get your code working I needed to use these Libriaries i found in MCUfriend.com
http://forum.arduino.cc/index.php?topic=292777.0
dmainmonRailes
Reply 2 years ago
You can download the libraries used in this here:
grantwcRailes
Reply 2 years ago
Same here. These are the only libraries that worked for me. Currently going through the changes so i can understand what had to be done to make this display work.
Thanks for the link. It is a relief to see the display finally working!
NicA8
2 years ago
i have two questions:
- There is a sketch for sleeping display (on/off or sleep mode)?
- How can i connect this display with Arduno Nano ?
Wesley R Tech
3 years ago
How do I plug it into the Mega?
