USB Keyboard Arduino Key Mapper for MacOS
About: I like electronic things :-)
I've switched from the PC to a Mac Computer and I wanted to still using a PC Keyboard, because I like the Layout. But then you got a problem with these keys: {}[]|<>@\ . And you can’t fix it in the MacOS System Settings.
I wanted a Hardware solution, because I don't wanted to update the Mapper Software year after year.
That's the reason for my project.
Supplies:
Step 1: What You Need
This is what you need:
  • Arduino Leonardo Board
  • USB Host Shield
  • Arduino Sketch “Keyboard Mapper”
Step 2: How to Build the Mapper
Do these steps to build the Mapper:
    • Connect the Leonardo Board with the Mac via USB
    • Upload the Sketch into the Leonardo Board
      (if you are using a normal PC Keyboard, then use the "KeyboardMapper4.ino"
      if you are using a Apple USB Keyboard, then use the "KeyboardMapperAppleKeyboard4.ino")
    • Stack the USB Host Shield on the Leonardo Board
    • Connect the USB PC keyboard with the USB Host Shield Port.
    That's it.
    Step 3: Use It
    The Mapper is working out of the box (all relevant keys {}[]|<>@\ are always mapped).
    But you can change additional Key Mappings if you press the Keyboard keys "ALT" and "ESC" at the same time.
    Then the Settings-Menü will printed on the screen (before this you should open a Text-Editor).
    Arduino Contest 2019
    This is an entry in the
      • Arduino Contest 2019
      • Party Challenge
        Party Challenge
