USB Power Socket in the Car
57,185
983
36
Though there is always an option of 12 volt adapters for vehicles to be used in cigarette lighter for charging mobiles n tabs but just for a better look I decided to create a USB power socket for my car.
Step 1: Disassemble USB 12V Car Charger for Mobile.
I disassembled a 12V USB car charger with 1amp and 2.1amp usb ports and removed the circuit board from the plastic casing.
Step 2: Preparing the Cover
Then I cut a piece of plastic equal to the size of the port where this socket has to be installed in the car. Cut a square box in the cover according to the size of USB port and a hole for led light. I applied carbon fibre vinyl sheet for refined look.
Step 3: Installation of Circuit Behind the Cover
Then I fixed the circuit board behind the cover using metal mender after which it gave this look.
Step 4: Wiring
Then I soldered the wires to the circuit board. These wires are to be connected to cigarette lighter for power. I also installed metal clips on the back of cover to fix it in the car.
Step 5: Final Look Before Installation
Step 6: Installation
After that I fixed USB power socket into the console and here is the final out come.
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
36 Discussions
Shakadula
Question 6 months ago on Step 4
Adding the clips is a very important detail. How did you attach the metal clips and what did you use? Thanks.
SUBYRIDA25
4 years ago
Hey, thanks for the great idea. I am putting this set up in a classic mgb, shhhh sacrilege yes I know... Quit question, the prongs that stick out from either side of my circuit, can I hook up my ground wire directly to them or should it be integrated with the circuit some how. Likewise, can my positive wire be hooked straight to the back? what happened to your prongs?
David97jockelleis
Reply 4 years ago on Introduction
I would use any USB car charger you could probably find one at a tech store or suermarker. really anywhere.
cyberblusky
Good idea based on wrong device. Sorry if I'm rude but the charger here showed is not able to supply 2.1A. It is a fake as many of them are: Look at the inductance if 1A pass trough it it will fuse :) also the IC is theorical limited to 1A ... look the datasheet or more easy put an amperometer.
I used a similar device: obviously it was not able to charge my device and i substitute the regulator with a real 5V 1A and the original inductance was melted in 5 minute. I changed also the inductance and all was fine but of the original device was survived only the case.
Please keep in high consideration the other user like bp_968 that suggest the usage of a proper device.
karimelsisy
Sincerely,im karim elsisy From the city of Tanta, Egypt Age 25 years
Possess good experience in the manufacture and distribution of electrical appliances
And exposure to the declaration of bankruptcy of the company and I want a partner wants to open a factory in Egypt
bp_968
If you search ebay you can find a great little 4 port USB charger/adapter that works on 12v from the car wiring. It can supply a total of 4-5 amps I believe. I think it was all of 3-4$. I plan to build it into the car similar to this excellent design!
kkockelkoren
4 years ago
My USB connection in the glove compartment, is only connected to my radio
kkockelkorenmaniacse
Reply 4 years ago
That's how I like it...
Was something I wanted to do for a long time
maniacsekkockelkoren
Yeah, I made this in my previous car, but directly on dash board, and it doesnt look fine to me. In my current car I have headunit with USB on face, but headunit is deeper then surrounding panels, so I do not need this. Meybe in next car I made it again and like you did it.
Reply 4 years ago
Thx man, for the compliment. I am happy with it....
pintail120
I support John Grimoldy, the iPhone and iPad have highly intelligent charging circuits built into them. They will only draw the current required. The "iDevice" is able to work out through the centre pins of the USB device and determine what is kind of charger is at the end of the cable, this is done by measuring the resistance of the centre pins of the USB connection. If you present the wrong voltage to iphone or ipad it will not allow charging to take place. These devices have heaps of built in protection, specially surrounding the fact that this is a LION battery.
boodah
Would love to see more about how you connected it to power.
Mocha0110
4 years ago
Jlichty fuse size depends on which kind of usb plug you'll use for your project. These usb plugs originally comes with suitable fuses so you may check internet for your usb plug. All of them gives suitable fuse size at their pages.
