USB Solar Charger
23,016
203
13
This Instructable will show you how to build a cheap and easy USB charger that charges by solar power.
Supplies:
Step 1: Acquire Materials
You will need the following:
•An Altoids tin
•a small car USB charger
•a small toggle switch
•a rechargeable nine volt battery and a clip
•a small solar panel
Other Tools/Materials: drill, Dremel, some wire
A screwdriver, and hot glue.
Step 2: Take Apart the Charger
Find the screw on the front face and remove it.
Take off all the casing.
Step 3: Cut the Holes
Use the Dremel to cut a hole for the USB port on the side and another hole for the switch. Drill two holes in the top for the solar panel wires.
Step 4: Soldering
Take the ground wire from the clip and solder it directly to the strips of metal that come out of the charger. Take the positive wire and solder it to one of the pins on the switch. Then put another wire leading from the switch to the positive strip of metal on the charger. - see the pictures for help.
Step 5: Put Together
Mount the components into their holes and hot glue them.
Step 6: Solar Panel
Lead the two wires from the solar panel through their holes.
Step 7: Solar Panel Prt. 2
Solder the panel's positive wire to the positive wire coming from the battery clip. Solder the panel's ground wire to the outside strip of metal on the charger.
Step 8: Wait
Let it sit in the sun for a couple hours and plug it in!
Step 9:
A full battery will give your iPod about 15% charge.
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    13 Discussions
    iDrwishjlandreth1
    Reply 4 years ago on Introduction
    Yes, the size of the solar panel will vary in the Amps coming out of it also in the voltage, however you need to Calculate the right size of the the Panel, the relation isn't straight forward meaning more amps meaning faster battery charger, what you need to do is charger the battery by around 10% of it's Amps, so figure out your battery rating then get your panel :)
    nsrt44
    hi I wonder if you could give the circuit diagram
    Ryhorn12
    5 years ago
    Why does it need a battery? Can't you just leave it in the sun? I ain't to technical you can see
    Marik I.
    5 years ago
    How long does it take to charge
    laffinm
    5 years ago
    Yes the project does work without the solar panel as I built it without the panel and decided to add it later on
    piedrabob78
    5 years ago
    Hi, would the project work if I skip the solar panel and plug it directly to a normal battery?
    osoriocj
    5 years ago on Introduction
    It would be great if you could place a link for each item (eBay, RS, Farnell). Also, a schematic would rock. Thanks for sharing.
    kmjrmalfunction
    5 years ago
    slap another 9volt in parallel in there and double your storage capacity
    thank to give your view, to improve the capacity.
    because i was thinking that how can i double the storage capacity.
    http://createyourownbots.blogspot.in/
    Solar Energy is the best source for Energy.
    this Solar phone Charger very important example of Solar energy for daily life.
    thanks.
    laffinm
    5 years ago
    Yes but I ran out of space on this one :(
