Ultimate Woodturners Tool Handle
2,756
77
About: i am Patrick from Patrick's Work Shop on youtube where i like to build lots of cool shop projects and other fun projects click on the link to see more https://www.youtube.com/user/Patricksworkshop
In this Instructable i will show you how to take an old drill chuck from an old drill and make a Ultimate wood turners tool handle that can be used on the lathe or as a super cool screwdriver
NOTE >you will need to take the drill apart by removing all the screws and take apart the transmission to get the chuck with the shaft still attached (you might need to cut some parts with hacksaw to get it off ) video on that soon
THINGS YOU WILL NEED :
1- old drill to take apart to get the drill chuck off
2- some scrap wood ,and wood glue
3- a wood lathe ,lathe tools ,
4-some epoxy
5- sandpaper,
6- some kind of finish i used spray lacquer
Step 1: Getting a Drill Chuck
you will need a drill chuck out of a old drill
take apart the drill any way you can without messing up the chuck
after you do this you should have something like this chuck in pic 2 and 3
Step 2:
now you will need some scrap wood to make a custom handle
I used some maple and walnut and ran it through my planer
my measurements are -
2 1/2 inches wide and 18 inches long
I used 5 layers to make up my handle blank
4 are 3/8 thick and one in the center is 3/4 inches thick
you can make yours any size to fit your needs
Step 3: Cutting Length
I cut my pieces to length at the miter saw to 18 inches long
Step 4: Glue Up Blank
I glued up the pieces in a cool pattern and clamped them over night for the glue to dry completely
Step 5: Trimming and Drilling
after the glue dried i trimmed the ends with the chop saw to even them up
then using a mt2 drill chuck in my lathe i put a 1/2 inch forstner bit in to make a recess in one end of the blank then using a 3/8 forstner bit i drilled 3 inches in for the chuck to fit tight
then i used epoxy to glue in the chuck to my blank
Step 6: Epoxy the Chuck
then i used epoxy to glue in the chuck in the hole of my blank
Step 7: Turning the Handle
i mount a drill bit in the chuck and mount it to my chuck in my lathe to turn the handle
i use a spindle gouge to turn the blank round and then turn it to a size that fits my hand
Step 8: The Funnest Part in the Shop
after i like the size and shape its time for everyone's favorite thing
sanding
i used some 150 sanding belt to do this step and i took it to 220
Step 9: Applying a Finish
i used a spray lacquer for the finish but you can use any finish you like
Step 10: And There U Have It
and that's all
now you can use it with any tool that fits
check out my video to see what i do with mine
thanks for checking out Patricksworkshop
Step 11: Use You Ultimate Woodturners Tool Handle
install a drill bit or a 3/8 lathe carbide tipped tool or use it as a screw driver make it your own and have fun
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    2 Discussions
    WoodCrafts 67
    2 years ago
    Hi Mate I just see this in youtube and see your link to here. I will say again. Mate this is outstanding work My Friend I am definitely going to be making one of these and also the chisels from Screwdrivers That I see in your other video. Thanks Mate . I am so happy right now :)
    WoodCrafts 67
    2 years ago
