Underwater Microphone (Hydrophone)
88,953
100
41
Construct a inexpensive hydrophone out of things laying around your house.
I decided to put up this instructable because (to my surprise) no one has a hydrophone instructable up yet. I made mine using a mixture of other people's hydrophone creations that I found through a google search and a bit of ingenuity.
Here's the parts that I used but it should be fairly easy to adapt whatever similar items that you can find.
computer microphone
plastic wrap
vegetable oil
solder
knife or scissors
bottle
( I used a small spray bottle that was originally some "energy-caffeine spray")
Supplies:
Step 1: Breaking Down Parts
You are going to dissasemble the computer mic so that you have the capsule and the cord seperated, I didnt put any pictures of this up because I already disassembled them before deciding to make an instructable, but the proccess is pretty easy and is a little different with every mic.
You also should have your bottle or container taken apart.
Step 2: Cut, Strip and Connect
Using a small pear knife make a hole in the top of the lid and feed the cord through. It is important to make the hole as small as you can so it as water tight as possible.
After the cord was in I stripped the wires and connected them to the Mic Capsule by carefully twisting the wires together.
Step 3: First Test
It is a good Idea to test the connection before soldering and wrapping everything.
Plug the mic into your computer or recording device and test it.
Step 4: Soldering and Wrapping Connections
If your test was successful then you can solder your connections.
If it was not make sure that your wires are in the right spot and that they are well connected also check the volumes of your recording equiptment.
There are a lot of different ways that you can do this, but you need to insulate the wires so that they do not touch each other, the mic capsule, or water.
If I had access to a glue gun I would of sealed them that way instead I used plastic wrap, and indiviually wrapped the connections and then wrapped them all together.
After you do this its a good idea to test the mic one more time.
Step 5: Fitting the Capsule
Now you should continue to wrap the capsule with plastic wrap until the capsule fits tightly in the lid, but not so tight that you can't fit the lid over the opening of the bottle this may take some trial and error.
Step 6: Vegitable Oil
Pour vegetable oil into the bottle until it is nearly at the top, leaving a little room for the mic capsule.
Push the lid over the bottle opening, the mic will dip into the vegetable oil and go into the bottle,
The lid should stretch and go over the bottle and create a near air-tight seal, some vegetable oil will probably come out be sure to wipe off the oil before putting it in water, you do not want any air in the bottle it should be full of oil.
I taped around the edge, where the lid was over the bottle and wrapped more plastic wrap around it to make sure it was sealed well.
It is also a good idea to seal the lid where the cord is at with hot glue or super glue.
Step 7: Done
Now you can test out your hydropne, its not exactly research quality or anything but it does work, you will also want to make some sort of weight to hold it under water as it does want to float.
A key ring with some old keys works great.
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    41 Discussions
    nortok00
    Question 4 months ago on Step 6
    Hi. I know this instructable is fairly old but hopefully it's still being monitored for questions. :-) Can someone please explain the purpose of the oil. When we speak the sound travels through air. Wouldn't this work the same way with the microphone inside the housing/casing (meaning the sound traveling through the air in the case) or does the oil serve another purpose like amplifying the sound or is it merely there to help keep water out?
    Boles373
    3 years ago
    Hi, how can I make an underwater speaker - small one.??
    danlancheros
    4 years ago on Step 7
    Hi, thanks for your post.
    Does the goldfish makes any sound? what kind of sound does it make?
    hra
    7 years ago on Introduction
    helo,,
    my I know where I can buy the Hydrophone another one???
    I need ur product,
    I hope u can help me,
    ooowyaa,, may I know, how u know the qualification or charactrstic of some bioaccoustic signal from the fish???
    thx lot
    TheDugger
    10 years ago on Introduction
    Having successfully built an underwater housing out of an ammo can (see instructions on this site), I am wanting to take the next step and get clear audio. Knowing nothing about hydraphone technology, I was with you until you submerged your mic into the oil. Why doesn't that render the mic useless? What role does the oil play?
    dosciaction_owl
    thanks, but i had a problem: the mic was still working after i submerged in into oil without closing the bottle, BUT after i closed the bottle, and the extra oil licked out, the mic became dead, not functioning anymore...(i tryed with 3 mics.. and alwaiìys the sa,me..). any idea why is that happening? is it possible that this is due to an excessive pressure of the oil against the micro membrane? any suggestion?
    burwuroaction_owl
    Yea and the hydrophone (in my opinion) would work better if their was a membrane (idk saran wrap) so that the vibrations will be able to be picked up better. and it wont break from pressure because of the oil keeping the pressure the same.
    TheDugger
    Well I finally got around to giving this a try. I lined everything up and assembled it just as instructed. I put it into the water to try and what recorded was a very faint sound of my kid's voices. I am going to give the condom approach a shot. If that doesn't work, I'll give up and buy one.
    belgvr
    9 years ago on Step 7
    would be great if you put some example audio of what you have got :D
    wupme
    Air ain't the problem, its just cruel to put a fish in such bowls. In some countrys (Germany for example) its actually illegal to put fish in such bowls, pet stores also don't sell them. You still can buy bowls of course, for food or decoration.... A fish needs a tank, plants, a water filter and some other fish of course. I actually got one 320 liter tank, and another 200 liter tank. And an 80 liter for raising babys.
    hogiewan
    I would think a piezo disc with sealant covering the side with the terminals would work as good if not better
    gegehogiewan
    I fully agree. I had seen somewhere about using an electret microphone . I did pur it in veg oil .... It worked nicely for a few hours ...Until the oil got into the work (beneath the cloth) ,then the sensitivity went way down. I did a second one to be sure and SAME thing I then used one little dynamic cartridge with a plastic cone (for resistance to oil), added an amplifier and it still work. I have ordered some piezo slabs to build into microphones(pressure transducers)they are cheap if they are not finished as full underwater microphone. The trick will be to protect from water.................
    action_owlhogiewan
    true dat, I didnt have a piezo element though... I heard you can get them off of those musical greeting cards
    Badgergirl
    ummmm, so you would use this to talk to your goldfish? SWEET!! Now all i need is a fish communicator to communicate with all the fish of the world so they can help me in my quest for world domination! Mwa ha ha ha ha ha ha ha ha ha ha :P
    matt_sawyersBadgergirl
    I have the whale speech plug-in for the communicator... Created from the research from the "Finding Nemo" movie...
