Updated Guide on How to Program an Attiny13a or 13 With the Arduino IDE
21,809
126
19
The ATtiny13 series chips are extremely cheap and useful chips for small projects that don't need a full Arduino, but due to very outdated tutorials and a lack of information, it took me the better part of a day to figure out how to program these with the Arduino IDE.
To fix this lack of information, in this Instructable, I will show you how to program your ATtiny13 or ATtiny13a with an up to date version of the Arduino IDE.
Supplies:
Step 1: The Hardware You Need
Required Hardware
• Arduino (Uno is the easiest, but any Arduino will work)
• ATtiny13 or 13a
• Breadboard
• Jumper Wires
Troubleshooting Hardware (not necessarily required)
• 10uf electrolytic capacitor
• Any large electrolytic capacitor (mine is 1000uf, but any capacitance 100uf and above will work best)
Step 2: Setting Up the Hardware
Connect the pins of the Arduino to the ATtiny as shown in the image or table below.
Important Note: Make sure to orient your ATtiny such that the indicator dot on your chip is in the bottom left corner as shown in the images (across from the 5v line). Orienting your ATtiny the opposite way can hurt the chip.
Arduino____________ATtiny13(a)
5v----------------------------Pin 8
GND------------------------Pin 4
Pin 13-----------------------Pin 7
Pin 12-----------------------Pin 6
Pin 11-----------------------Pin 5
Pin 10-----------------------Pin 1
Step 3: Setting Up the Arduino As ISP
Navigate to Files-Examples-ArduinoISP and click on ArduinoISP. Upload this sketch to your Arduino. Now your Arduino is set up as a programmer for programming other chips.
Step 4: Downloading the Attiny13(a) Core Files
To program the ATtiny13 or 13a, you will need to install the core files. For this we will be using the core files created by sleepmanj, which I find to be the easiest to install and the best to use.
To install these files, open your Arduino IDE and navigate to the files drop-down menu, then select preferences. Paste this URL "https://raw.githubusercontent.com/sleemanj/optiboot/master/dists/package_gogo_diy_attiny_index.json" where it says "Additional Boards Manager URLs:". If you already have a URL here and want to add more, separate the URLs with a comma and a space.
Now navigate to tools-board and click on Boards Manager.... Now scroll down until you see DIY ATtiny and click the install button (it will default to the newest version).
Step 5: Burning the Bootloader to the Attiny
Go to Tools-Board and select ATtiny13. After selecting ATtiny13, navigate to Tools-Processor Version and select either ATtiny13 or ATtiny13a depending on your chip. Do not change any other settings until you know what they do, they can mess up what you are trying to accomplish. Finally, click the Burn Bootloader button at the bottom of the tools drop-down menu.
Important Note:You should make sure your programmer is set as "Arduino as ISP"
Step 6: Programming the Chip
You're at the homestretch! To make sure everything is working, let's upload the blink sketch to the ATtiny. Navigate to Files-Examples-Basics and select Blink.
There are a few changes we will need to make though. In the program, change every instance of "LED_BUILTIN" to "4" because our ATtiny doesn't have a built in LED. This "4" corresponds to pin 3 of the ATtiny (This can get confusing, you can reference what number in the IDE corresponds to what pin on the diagram in the "Troubleshooting" step). Now you can upload this code to your ATtiny through your Arduino by clicking the upload button.
To test to see if it worked, connect an LED (along with an appropriate resistor) between pin 3 on the ATtiny and ground as shown in the diagram and image above. The LED should be blinking on and off. If it is, congratulations! You now know how to program an ATtiny13 or 13a! You can now disconnect all wires except the 5v and ground.
If your LED isn't blinking, don't worry, proceed to the troubleshooting step to fix your problems.
Step 7: Troubleshooting
Something always goes wrong when working with new things, that's ok! Let's try to fix these issues. Try these in the order they show up.
• Double check all of your connections and your orientation of the ATtiny and LED.
• Re-upload the ArduinoISP sketch to your Arduino.
• Connect a 10uf electrolytic capacitor between ground and reset on your Arduino. Make sure to plug in the capacitor in the correct orientation, negative goes to ground.
• Connect any large capacitor between the 5v and ground on the breadboard, this will help smooth out any voltage spikes.
• Make sure enough power is getting to the Arduino that is programming the ATtiny, a 9 volt battery might not work.
• Switch out your Arduino with a different Arduino
• Make sure you're using an up to date IDE and up to date core files
• Click on tools and make sure the drop down menu looks the same as the menu shown in the "Burn the Bootloader" step. If something is different, change it and re-burn the bootloader.
Step 8: Great Job!
Congratulations on programming your ATtiny and thanks for reading my Instructable!
3 People Made This Project!
  • Party Challenge
    Party Challenge
  • Gardening Contest
    Gardening Contest
19 Discussions
andrea biffi
12 days ago
Thanks that will be super-useful!
PatrickB239
Tip 4 weeks ago
I done this with an MEGA2560. Here you have to use (on some fake boards) Pin 10 instead of Pin 53 (SPI)
Arif17
9 months ago
great Tutorial ever..!
Flynns_Place
10 months ago
I made this last night and it worked great. I've been looking at other tutorials on how to SIMPLY program the ATTiny13 and most of them contained a bunch of command line operations outside of any useable IDE. Since I had my Arduino Uno sitting around doing nothing, I decided to try it. Thanks for the clear step by step.
Now I can get on with programming it for some of my other projects!
Gajeboo
Question 1 year ago
Thank you very much... Its worked! I did it.
But how to use the other three pins that being used which connected to arduino pins : 13, 12, 11 in program?
This is the link my work :
https://youtu.be/oldyoqBlpY8
Gajeboo
Question 1 year ago
MarcosG19
1 year ago
Funcionou perfeitamente, muito bom o tutorial!
berniegb
1 year ago
Arduino: 1.8.5 (Mac OS X), Board: "ATtiny13, ATtiny13a, No (ISP Programmer Upload), 9.6MHz Internal Oscillator, Millis Available, No Tone, Better Or Equal 1.666% Error (Default), Bin, Hex, Dec Supported, Half Duplex, Read+Write, LTO Enabled, 2.7v"
/Users/berniebenson/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/Users/berniebenson/Library/Arduino15/packages/diy_attiny/hardware/avr/2017.10.29/avrdude.conf -v -pattiny13 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uhfuse:w:0b11111011:m -Ulfuse:w:0x7A:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/berniebenson/Library/Arduino15/packages/diy_attiny/hardware/avr/2017.10.29/avrdude.conf"
User configuration file is "/Users/berniebenson/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done. Thank you.
Error while burning bootloader.
This is the error info when trying to burn the bootloader.
Any suggestions please
Regards
Bernie
ArsS1
1 year ago
When I want to programing
I encountering this error
Arduino: 1.8.1 (Windows 10), Board: "ATtiny13, ATtiny13a, No (ISP Programmer Upload), 9.6MHz Internal Oscillator, Millis Available, No Tone, Better Or Equal 1.666% Error (Default), Bin, Hex, Dec Supported, Half Duplex, Read+Write, LTO Enabled, 2.7v"
Sketch uses 942 bytes (91%) of program storage space. Maximum is 1024 bytes.
Global variables use 34 bytes (53%) of dynamic memory, leaving 30 bytes for local variables. Maximum is 64 bytes.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
An error occurred while uploading the sketch
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
BallscrewBob
1 year ago
Just been given some ATTINY 13A and already have a home made shield that works great for for 45's and 85's but I get the following and wonder if these is any way to sort this out ?
Using IDE 1.8.3 or above all give the same issue under win 7 X64 pro.
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
System wide configuration file is "d:\Users\Bob\AppData\Local\Arduino15\packages\diy_attiny\hardware\avr\2017.10.29/avrdude.conf"
Using Port : COM20
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATtiny13
Chip Erase delay : 4000 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 64 4 0 4000 4000 0xff 0xff
flash 65 6 32 0 yes 1024 32 32 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
this check.
ramoal
1 year ago
Hi, when I clic on Burn Bootloader I've this message:
avrdude: failed to open parallel port "/dev/parport0"
Please any helps?
THANKS IN ADVANCE.
Have you made sure the correct port is selected and your programmer is set as "Arduino as ISP"
PaulH433
1 year ago
Perfect! Works well for me. Now I need to find a project for the 10 ATtiny13a's that just arrived from China :-)
p.s. I think Programmer needs to be "Arduino as ISP". Step 5 shows "AVRISP mk2".
ramoal
1 year ago
techn0man1ac
1 year ago
Неплохо, понравилось.
Tominaz
1 year ago
near! will definitely look into this. great Documentation
