Using Breakout Board for ADMP401 MEMS Microphone on PcDuino
Module introduction:
Breakout Board for ADMP401 MEMS Microphone is a supersensitive omnidirectional microphones.Its PCB is very small, signal output is simple, with only 3 signal output, one VCC (positive power), one GND(negative power), one output(signal output), when the voice is changing around the module, the output signal (output) is also chaging. So we can use the pcduino ADC function to collect speech signal (Of course, the sample rate is not very high)
Step 1: Wiring Diagram
Step 2: Sample Code
#include
int adc_id = 2; int delay_us = 100000; int HistoryValue = 0; char buffer[100]; void setup() { memset(buffer,0,sizeof(buffer)); } void loop() { int value = analogRead(adc_id); // get adc value value = ((float)value/4096)*sizeof(buffer); if(((HistoryValue>=value) && ((HistoryValue - value) > 2)) || ((HistoryValue 2))) { memset(buffer,'*',value); buffer[value] = 0; printf("%s\n",buffer); } HistoryValue = value; }
Step 3: The Results
When we touch the module with hand, we can detect the sensor output:
When the sound changes , the reversed waveform like spectrum will be shown on the screen.
    • Weaving Challenge
      Weaving Challenge
    • Pie Contest
      Pie Contest
    • Pocket Sized Contest
    3 Discussions
    VinodN5
    3 years ago
    if(((HistoryValue>=value) && ((HistoryValue - value) > 2)) || ((HistoryValue 2))) //what is the HistroryValue2 will do here ?
    at this instruction i am getting the error as
    MEMS_microphone.ino: In function 'void loop()':
    MEMS_microphone:22: error: expected ')' before numeric constant
    MEMS_microphone:29: error: expected ')' before 'HistoryValue'
    MEMS_microphone:29: error: expected ')' before ';' token
    VinodN5
    3 years ago
    VinodN5
    3 years ago
