Using a Clinometer to Measure Height
520,776
323
54
In this Instructable, I'll show you how to use a clinometer to measure the height of a tall object (for help constructing your own clinometer from basic classroom materials, click here).
What you will need;
Clinometer
Tape measure
Paper
Pen or pencil
Assistant
Supplies:
Step 1: Pick a Spot
Pick a spot to measure your object (I measured a telephone pole).  You should be far enough away from your object that you can see the top of it, and you need to be on level ground with the base of the object.  I like to set something down by my feet once I've picked my spot, so that I can easily come back to it.
Step 2: Measure Angle
Here's where we bust out our handy clinometer.  Look through the straw of your clinometer at the top of the light pole (or whatever object you're measuring).  The weighted string should hang down freely, crossing the protractor portion of the clinometer.  Read the angle shown, and subtract from 90° to find your angle of vision from your eye to the top of the pole (it can be helpful here to have an assistant to read the measurement while you look through the straw).  Record your results on your paper.
From my spot, my clinometer (read by my assistant) showed 55°.  Subtracting from 90°, that indicated that I looked at an angle of 35° to the top of the telephone pole.
Step 3: Measure Distance
Once you have your angle of vision, use your tape measure to find the distance from the spot you're standing to the base of the object you're measuring (an assistant comes in handy here, too).  We must know how far away you are to accurately calculate the height.
My spot was 15.6 meters from the base of the telephone pole I measured.
Step 4: Find Your Eye-height
The last piece of data you need to calculate the height of your object is the height from the ground to your eye (your eye-height).  Have your assistant help you measure this using your tape measure.
My eye height was recorded for this example as 1.64 meters.
Step 5: Draw a Picture
Time to move inside.  In calculating the height of the object you just measured, I find it helpful to begin by drawing a picture and labeling it with all of the information I have.
Step 6: Model As a Triangle
The next step is to simplify your drawing to model your system as a right triangle.  Label your triangle with the angle you read on your clinometer as well as the distance you were standing from the object (we don't need the eye-height just yet).
Step 7: Solve for X
We can find x in this triangle (which represents the portion of the height from eye-level up) by using some basic trigonometry, specifically the tangent ratio of the triangle:
tan(angle) = x / distance
Multiply by the distance on both sides and you get:
x = tan(angle) * distance
Use a calculator to multiply these together and get a decimal value (be sure your calculator is in 'degrees' mode, rather than 'radians'!).
In my example:
tan(35°) = x / 15.6
x = tan(35°) * 15.6
x = 10.92 meters
Step 8: Combine With Eye Height
To find the height of your object, bring this x value back to the original drawing.  By labeling it, we can see that the height of the object, h, is equal to the x value we just found plus the eye-height we measured earlier:
h = x + (eye-height)
In my example:
h = 10.92m + 1.64m
h = 12.56m
There you have it!  A few basic classroom materials and a little bit of trigonometry and you can measure the height of anything around you!
3 People Made This Project!
  • Party Challenge
    Party Challenge
  • Woodworking Contest
    Woodworking Contest
54 Discussions
AaronH196
Question 2 months ago on Step 8
What if another person tried to determine the height of the object and the person had a different height then the first person who tried to determine the height that means the height from the second person eyesight measurement to the ground will be different than the first persons measured so this means you will have 2 different angles of elevations and this will obviously give you 2 different answers if you solved it the same way, so does this mean it's accurate or not accurate if it is accurate how can find the actual height of the object with 2 different people with different heights?
1 answer
dmuldoonllaAaronH196
Reply 2 months ago
Two people with different heights measuring from the same place will get different angle readings. When you plug those in to the Tangent, the difference in results will cancel out the difference in eye-height, giving both people the same total answer.
erenames16
1 year ago
Thank u very much. I would have been lost and fail my math assignment.
britjohnson0100
1 year ago
I used my phone with a straw on top and the compass app (the apple compass has a level, which is nice)
another thing i noticed is that if you keep walking towards the object until the clinometer says 45 degrees, the distance between you and the object is exactly the height of the object (+ your eye height)
GangavarapuJ
3 years ago
Thank you very much. With out this it is impossible to complete my math activity
AngeliM1
3 years ago
THANK YOU SO MUCH
MANISH KUMART
3 years ago
it was very helpful for my school project!
DemolisionWolf
5 years ago
Great instructable. im glad to see this tool on the site.
People have been mentioning the BSA method, which is fine, but the accuracy compared to a protractor and tape measure will be much less. And if you don't need accuracy, why even use the stick, just eye-ball it. (My two cents)
brojer
6 years ago on Step 8
BSA handbook has an easier method that doesn't require an assistant or math or a protractor. Just cut a stick at eye level push stick into ground and lie down with feet against stick. When top of object is level with top of stick, mark where you eye is and measure to base of the tall object.
There is a little mistake in your logic , formula
4. must be H=P(sin phi)
5. mus be X=P(cos phi )
try it with a value phi = 85 and you will see when you trace it on scale
w9vhe
6 years ago on Step 7
Shows how long it's been since I used any algebra on purpose, but how did you get the 35 degrees for the angle?
T_TX
I'm not seeing where you used the eye height in your calculations. Did I miss something?
dmuldoonllaT_TX
Reply 6 years ago on Introduction
We added the eye-height to the height (x) we found in the Tangent calculation to get the final height.
1943casey
If you are in Britain, the clinometer shown here is called a protractor available at most stationers, this method only works on level ground, more maths if your on a slope
