V Tool for the Lathe
1,625
8
About: I´m a Youtube and Twich streamer on Creative #woodworking, I do ugly fulgy stuff from reclaimed wood and other materials.So keep recycling, lets make it fun !!
I made the tool from pallet and an old file .
Sorry if i don´t use the correct terms i do this for fun i hope you all enjoy !!!
Links to the:
Video in case you have seeing on the mobile
Follow me on Twitch
Follow me on Instagram
Subscribe to my Youtube channel
Step 1: What Do You Need
The awesome free palette wood and an old file
Step 2: Get Your Wood Straight
Plane down the pallet wood straight so you can have a nice glue joint!
Step 3: Glue and Clampsp
Make sure you use a nice amount of glue and a good amount of clamps so the wood won't split.
Step 4: Cleaning the File
I used a grinder to clear all the file edges. Then used a water sand paper to sharpen all the edges.
Step 5: Plaine Again
Plained the blank so it your be square again !
Step 6: Cut!
I cutes 2 equal sizes to make a square blank for the handle
Step 7: OMG PLAINE AGAIN !!!
Yap plaine both to the same thickenness !
Step 8: Glue It "one Last Time"
I glue again . But with reverse so it would give a diferent look to the tool!
Step 9: Cuting the Blank
I dicided how long i wanted the handle and cut it to size !
Step 10: Turning
I turned the handle to a shape that i like and feel confortabale with !
Step 11: A Piece of Pipe "yummi"
I cuted a piece o Inox steel pipe to use as a piece to prevent the wood from crackle when you add the tool tip !
Step 12: Drill Drill a Hole
A hole to the tool tip . I tried to drill as straight as possible... a hole for the tip in the video did´nt loock that straight damit. the eye meter failed me !!!!
Note: normaly all my megurments are all by eyemeter.
Step 13: Pipe
I added the pipe part, and glue with CA glue and a few taps with my mallet , and bam steel put in its place
Step 14: Tool Tip
I did the same for the tool tip .Added CA glue hammer in with the malet and VOILA new Tool
Step 15: The Happiness
The end
The happiness of having a beefy new tool from old Junk !!!!!
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    3 Discussions
    buck2217
    2 years ago
    Not sure how safe this is as lathe tools are usually made of carbide steel and files can be all sorts and are usually more rigid. There is a danger that this could shatter in use
    TrashWoodshopbuck2217
    Reply 2 years ago
    @buck2217 since is just to some small V shape cut in the profile it should be ok i will make sure i will update id anything happens
    buck2217TrashWoodshop
    Reply 2 years ago
    Its not so much that it is more the forces on the tool in use. The metal in a file has less temper and thus give than that in a purpose manufactured turning tool. I'm sure it will work fine but just be careful
