Water Powered Flashlight
294,092
2,494
224
About: Hi I'm Angelo! I am a college student taking my engineering majors in BS-EE/ BS-ECE at the DLSU. I use my course as an inspiration for making my current projects! I've been posting projects here ever since I...
Batteries are too mainstream, let's make Water Powered ones! The DIY flashlight never runs out of batteries, water is all around us and will never run out. One of today's causes of pollution is the improper disposal of batteries containing heavy metals such as lead and mercury. The answer, using water as electrolyte!
Imagine, running wall clocks for 6-12 months with water, you'll never need to leave your house just to buy batteries and there's no need to recharge them. What could be more convenient than replenishing your batteries with tap water? :D
The flashlight runs 30mins continuously with tap water and 2 hours with saltwater. Not bad for a single celled prototype :D This thing also works well with calculators, clocks & radios Remember, adding a second cell triples the glow and lighting time!
How Does It Work?
This is a type of battery called the "Galvanic Cell", having 2 different types of metals and is connected by a salt bridge. It works like your typical battery but uses water as its electrolyte. If you want to read more about how batteries work "click here" The output voltage is pretty faint and isn't enough to run a single LED. By the help our trusty "Joule Thief Circuit", the LEDs would glow even at low voltages.
Is It Really Powered By Water?
Well not really, the water serves as an electrolyte, a replacement for toxic chemicals used in regular batteries, which usually ends up in dumpsites. So why call it water powered? Of course no one would be interested in the title "Galvanic Flashlight" plus that's what easily pops up in people's minds. The Redox reaction takes place in this project.
Practical Uses:
1st.) If you got lost and stranded out in the woods, you can't rely on batteries, eventually they run out. A mini version would save stranded people in the woods. Just go to the nearest river and fill her up! Whala, you have light!
2nd.) School science experiment
3rd.) A fun and educational project for all ages!
______________________________________________________________________________
Like Our Facebook Page, Get more updates!
WATER POWERED FLASHLIGHT VIDEO!
A Larger Scale Water Powered Project (a.k.a Galvanic Cell):
Step 1: Gathering Tools & Materials
Parts & Materials:
- PVC Pipe 4" Long (3/4"‎Ø)  [Local Hardware]
- PVC Coupling 3/4" to 1" [Local Hardware]
- Recycled 3xLED Torch  [Inventory = Free]
- Toroidal Core/ Bead  [Recycled From CFL Bulb]
- 2N3904 Gen. Purpose NPN Transistor [Radioshack]
- 1K Ohm Resistor (1/4w) [Radioshack]
- Cooper & Zinc Strip  [Local Hobby Shop]
- Magnet Wire/ Copper Wire [Inventory/ Local Hardware]
- 4 Sheets Of Tissue Paper [Toilet/ Bathroom]
- 2x2" Sheet of Acetate [Bookstore/ Office Supplies]
Tools & Equipment:
- Leatherman MultiTool
- Soldering Iron
- Hot GlueGun
- Teflon Tape
- Super Glue
Step 2: Preparing the Power Cells
The power cell is your flashlight's main source of energy. Basically there are two strips of metal, one for the anode and one for the cathode. The "Copper Strip" will provide the positive energy while the "Zinc Strip" for the negative.
Procedures: Assembling The Power Cell:
1st.) Roll tissue paper around your "Copper Strip" until you reach the 3rd sheet.
2nd.) After reaching the third sheet, roll the "Zinc Strip" until you reach your final sheet, which is the 5th sheet.
3rd.) Now tie some copper wire around the PowerCell, this prevents your tissue from tearing once it gets wet.
4th.) I recycled a pulley since it fits snugly on the PVC Coupling, puncture 2 slits for the metal strips to fit in.
5th.) Insert both metal strips through the pully's hole and seal/ waterproof it using epoxy/ superglue/ hotglue.
Step 3: Assembling the Joule Thief
What's A Joule Thief?
A "joule thief" is a circuit that helps drive an LED light even though your power supply is running low. What can we do with it? We can use it to squeeze the life out of our drained batteries. Bottom-line, this circuit makes LEDs glow even at low voltages.
Let's get started! Hummm, you probably encountered a joule thief before. Lucky for you I have a more detailed guide about making a simple joule thief found here: Making A Simple Joule Thief (made easy)
If you already know how to build one, you can just follow the simple diagram from above. I needed to make my circuit more compact so I soldered my transistor below the LED's board while the toroidal core was glued above the LED's board.
Click Me! Visit my full tutorial on building a joule thief.
Step 4: Combining the PowerCell & Joule Thief
You probably came to a realization that the flashlight, uses to two separate projects, the PowerCell and the Joule Thief circuit, in order to work.
For this step, solder the wires of the "PowerCell" to the "Joule Thief" then apply superglue around the coupling. Finally superglue the LED's reflector to your coupling.
Step 5: Preparing the Water Storage Cylinder
Get a 4" long PVC pipe then glue a small piece of acetate, this let's you see if the flashlight still has water.
Step 6: Fill Her Up!
Just fill in tap water and you are ready to go!
Attention: Tap water won't last for more than 30 mins. They lack electrolytes. Saltwater will boost to the flashlight's glowing time but still it would only last for 2 hours. Vinegar & Gatorade works best, since they both contain electrolytes (lots of them).
Adding a second cell triples the glow and lighting time!
Tested Liquids As Fuel:
- Tap Water = 0.5v - 0.6v (@400 mAh)
- Saltwater  = 0.6v - 1v    (@600 mAh)
- Vinegar     = 0.8v - 1.2v (@850 mAh)
- Gatorade   = 0.9v - 1.1v (@700 mAh)
Step 7: You're Done!
Let's light up the world, with free energy! Also, don't be shy to share your own version of the Water Powered Battery, just leave a comment & photo below.
Thanks for Viewing!
Make It Glow Contest
First Prize in the
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
224 Discussions
icekid
5 years ago on Introduction
Oh dude thanks for this, voted too! We have an investigatory project for chem class. A project like this would do great. How about: "Testing the feasibility of galvanic batteries" (a.k.a "Water Powered") for the title?
ASCASicekid
Reply 5 years ago on Introduction
That's a good title :)) Similar to our last year's IP title, about the feasibility of hydroponic planting.
Electrolytes
Question 7 weeks ago on Step 7
Is it possible to add on/off switch?
GabrielC273
Question 2 months ago
From what thing did you get the pulley? Your answers would be very helpful!!!
TGIK
4 months ago on Step 3
If you don't want to go through the work of constructing a joule theif circuit, a 5252f is a IC they use in solar lights that use a small 4 pin package and a inductor to do the same thing, you can get them fairly cheap on ebay.
Battlespeed
4 years ago on Introduction
Very neat.
As an aside, this bugs me whenever I see it: "Whala" or "walla" etc. The word is "voila" - a common French word - and I also don't know why so many people think the word starts with "w" because the "v" IS pronounced - as in VWALLAH.
pmoragaBattlespeed
Reply 6 months ago
I learned the correct spelling, origin and usage of "voila" when a teacher graded a paper I had written which contained the word ”volla." I will always be thankful to my fifth grade teacher for his guidance.
(Note: Although this is a true story, I do feel bad about poking fun about an otherwise well written Instructable. Don't let us snarky English majors discourage you from sharing your scientific knowledge.)
SirCooksalotTimothyJ999
Reply 3 years ago
This is one of my favorites too.... It's usually 'viola' which doesn't make phonetic sense either. Happy to see other voila police out there cleaning up the world.
PsalmsS1
1 year ago
Can I use aluminum copper battery instead of zinc?
Annie&
1 year ago
The first law of physics is: you can't get something for nothing. If this was as good as it seems, power companies would insert metals in the ocean and get free electricity forever. The battery has to wear out after so many "charges". They don't say how many. But here's a thought would make a great buoy or yacht light.(for as long as it lasted).
DeepakB34
2 years ago
wow thats good
opeyemi.seun2
2 years ago
Nice Instructable bro, just wanna ask whether the readings are from open circuit or you have the LED module connected?
