Wedding / Event Photobooth
14,312
214
41
Hi everybody,
I got married last year, when we're looking for preparation of the D-day, we went on a lot of wedding conventions.
On every convention there is a Photobooth renter, I thought that a photobooth was a great idee for a wedding, each guest could be have fun with it and could leave the wedding with a memory of the party.
I was told to my future wife: "I have almost everything I need to make a photobooth at home, I will do that !".
So here you will find how to make a Photobooth for your wedding or another event.
Since the wedding we lent it to friends for various events (birthday party, baptism...), so fun.
Step 1: All What You Need
This is the list of all what I need to do my Photobooth:
  • 1 Raspberry pi (for me Raspberry 1 model B because I've got it before but you can take a newer version)
  • 1 SD Card for the raspberry
  • 1 micro USB cable + power adapter 5V and 2A (to power raspberry)
  • 1 Camera module for raspberry
  • 1 USB Hub powered
  • 1 photo printer compatible with raspbian (for me HP Photosmart 475)
  • 1 massive arcade button 100mm with led
  • 1 12v transformer for button led
  • 1 PC screen (if it's not an HDMI screen you will need an HDMI adapter to plug to Raspberry)
  • 3 spotlights with transformer
  • 1 desk grommet of 80mm to fix the camera module
  • Pieces of wood to make the box
  • All decoration you want to embellish your Photobooth (for me pink wallpaper).
Step 2: Prepare Your Raspberry Pi
First of all you have to prepare your Raspberry pi and test all your installation with the program (I will give you my program don't worry ;)).
1. Load the OS of Raspberry pi into the SD card => Raspbian (Linux OS for Raspberry)
From your computer (windows / mac / linux):
  • Download Raspbian with desktop from this page: https://www.raspberrypi.org/downloads/raspbian/
  • Download Etcher and install it from this page: https://etcher.io/
  • Connect an SD card reader with the SD card inside.
  • Open Etcher and select from your hard drive the Raspberry Pi .img or .zip file you wish to write to the SD card.
  • Select the SD card you wish to write your image to.
  • Review your selections and click 'Flash!' to begin writing data to the SD card.
You can find more information on this page: https://www.raspberrypi.org/documentation/installation/installing-images/
2. Enable Camera module
To enable the camera module there is a little configuration to do: https://www.raspberrypi.org/documentation/usage/camera/
3. Prepare Raspbian with all librairies you need
Step 3: Wire Arcade Button on Raspberry Pi
On my program, I set the button on the GPIO Pin 25 of the raspberry pi 1 model B
Step 4: Import Program From Github
You will find program on Github: https://github.com/sabat54i/photoboothdiy
The code is in camera.py file, you will need the images folder for the main wallpaper of the photobooth.
On the code you can change the path of the folder where pictures will be saved.
To run it you just have to launch a terminal, navagate to the program folder and type "sudo python camera.py"
If you want to test it without a button wire on GPIO Pin 25 of the raspberry, you can push down arrow of your keyboard.
Finally, I wanted to run the program at startup of the raspberry pi so I followed this tuto https://www.simplified.guide/linux/automatically-run-program-on-startup
The script which launch at startup is on the Github: photobooth-script.sh
Step 5: Make the Box
You will find here all step of construction of the box
Step 6: Demo
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    41 Discussions
    jarizla
    Question 2 months ago on Step 5
    Very nice project!
    I've used your code to make my own photobooth.
    It all works great, expect for the printing part.
    The printer works, i can print anything from the raspberry.
    Do I have to make some changes in the camera.py to get it working?
    Hope you can help me out!
    Beedee_1
    4 months ago
    Congrats on your wedding!
    This is very helpful and ive decided to follow this steps for my upcoming baby shower but for the arcade button wiring do you have any details or steps on connecting the button to the gpio? Which wire do i need and how to connect the transformer? Sorry haven't worked on wiring these before.
    Thank you!!
    ryspi3_14
    Question 11 months ago
    I've followed all the instructions and installed cups but I get an error saying cups module not found when i run the camera.py file. I've copied and pasted the error message below.
    Traceback (most recent call last):
    File "camera.py", line 6, in <module>
    import Cups
    ImportError: No module named Cups
    sabat54ryspi3_14
    Answer 11 months ago
    Hi,
    I think you Forgot to install CUPS on your raspberry. It is explain on step 2 how to install it.
    JuanC393sabat54
    Reply 8 months ago
    Same problem, I re installed everything and no luck
    sabat54JuanC393
    Reply 8 months ago
    I thank I Forgot à step, installing cups for python. To do that open a terminal and type apt-get python-cups. I think this Step will solve your issue
    JuanC393sabat54
    Reply 8 months ago
    I did install python cups but when i run the code it gives me a
    Error
    ImportError: No module named cups
    I tried re-installing and no luck
    ryspi3_14ryspi3_14
    No it's definitely not that as I said in my post I've installed cups. I've used cups to test the printer. But it's not recognising cups when running the camera.py code in terminal.
    Loursapoilsryspi3_14
    Reply 10 months ago
    Hi,
    I had the same problem resolved with the command sudo apt-get python-cups
    because you need to install cups for python.
    hope this helps if you didn't find the answer
    fibo_8
    Question 10 months ago
    The photobooth module crashes when I go to press the button to print and nothing is sent to my printer. Do i need to make a configuration?
    1 answer
    JuanC393fibo_8
    Answer 8 months ago
    Its happening to me also, did you figure it out?
    sabat54superbuilderlego
    Hi,
    You can use my code but you have to modify it just a little bit to remove the printing part (remove from line 354 to line 392). Pictures will be saved on the raspberry pi.
    p0laksabat54
    Reply 9 months ago
    hello where are they registered? and how are the photos recovered when the script is launched?
    Loursapoils
    Hi,
    Awesome tutorial for an awesome project.
    Just one point to add, you forget to put the information to install cups for python.
    You put the tutorial for installing cups on the raspi in general.
    But if you not install it for python, you will have the error that you see in some of the comments.
    Just use the commande sudo apt-get python-cups and all will be fine.
    I made it, just the camera modul which seems have a failure, but it's really great.
    Thanks for all.
    1 answer
    fibo_8Loursapoils
    Answer 10 months ago
    My button doesn't work?
    Also when I use the arrow key to try printing. The whole thing freezes and I have to restart the pi.
    Any ideas?
    MariuszC4
    hi , i have a problem with install when i try run : sudo python camera.py then i have :
    pi@raspberrypi:~/Downloads/photoboothdiy-master $ sudo python camera.py
    import cups
    Can you help me ?
    LoursapoilsMariuszC4
    Hi,
    sabat54MariuszC4
    Hi MariuszC4 ,
    fibo_8
    I keep receiving the error...
    Any tips on how to resolve this?
