What Is a Resistor | Basics
3,832
48
6
About: Hi, I'm Nemeen, Electronics Enthusiast! I have seen a huge decline in electronics hobbyist in past few years. I started this channel in order to inspire you to create. Hopefully, you will find something tha...
If you have ever built a circuit, then you might have come across this component, this is a resistor. So how does it works let’s find it out!
Step 1: Watch the Video !
I have made video on Youtube which is much easier to understand check it out !
Step 2: Basic Introduction
Resistor is an electrical component that resists rate of flow of current and unit of resistor is Ohms.
it is represented by two symbols show above.
Ohm's law
The current I is equal to the voltage V divided by the resistance R
also represented by V=I*R
Step 3: Resistors in Series and Parallel.
Resistors in series
The equivalent resistance of resistors in series is the sum of the resistance values:
Req= R1+ R2+ R3+...
Therefore equivalent resistance increases
Resistors in parallel
The equivalent resistance of resistors in parallel is given by:
(1/Req)=(1/R1)+(1/R2)+(1/R3)+...
Therefore equivalent resistance decreases
Step 4: Voltage Drop
This happens when resistors are connected in series and the drop in the voltage can be calculated using the formula
V1=(R2*V)/(R1+R2)
Step 5: Power Rating of Resistor
There are various types of resistor such as Shunt, Power, Variable etc.
But most importantly Power rating is a crucial factor while designing the circuit or else You can see what can happen in the circuit in this Video.
Step 6: Application
Lets say we want to power a LED which requires 3V and 20 mA to operate and we want to power it using 9V battery, then we need a resistor otherwise LED will get damaged instantly because of excess current. The value of the resistance can be calculated using the ohms law, which says voltage equal to current times resistance. So our voltage is 9V and current is 20mA so resistance value comes out to be 450 ohms but I have 1k ohm resistors so I will add 2 of them in parallel so equivalent resistance becomes 500 Ohms.
Step 7: Thank You
If you like my work
Feel free to check out my YouTube channel for more awesome stuff: https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects and behind the scenes information
https://www.facebook.com/NematicsLab/
https://www.instagram.com/nematic_yt/
https://twitter.com/Nematic_YT
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    6 Discussions
    mabbaskhann
    9 months ago
    Thank you for sharing this beautiful content. It is the very basic information about the resistor. I have also made effort to create a post about resistor basics just like you. I tried my best and share everything I personally know about the mentioned topic. Hopefully, you will like it too. Here is the link to the post. https://www.yamanelectronics.com/resistor/
    NagelmaierP
    1 year ago
    In step 6 you say that the current is 20mAH, but this is a capacity, it should say 20mA.
    Also you would not use 9V in the calculation, but 9V minus the working voltage of the LED, so 6V.
    Anshu AR
    1 year ago
    Nice instructable!
    Just a small question off the topic, Whats that multimeter you are using?
    I mean I have to buy one. So is that a reliable one?
    gm280
    1 year ago
    When you really understand electronics really well, it is amazing how many components you can literally make with household items. I love making circuits for my needs.
    michaelthehutt
    1 year ago
    nitpick: for resistors in parallel, you have "Req=(1/R1)+(1/R2)+(1/R3)+...", but I believe that should be "1/Req = (1/R1)+(1/R2)+(1/R3)+..." (ie - invert the sum of the inverted resistance values).
