Wheeled Van Bed
1,113
10
About: Currently splitting time between college, work, Army, and my own studio. My interests range the full spectrum, but is always willing to help.
Wanna camp or cross-country travelling, without hotels or tents?
Try a bed that goes where you go and is already set up!
Wheels on the bottom make insertion and removal a breeze with this bed
Step 1: Measure and Cut
I had a twin size mattress from a homemade bunkbed my sibling grew out of, so I already had the base started
The base is made entirely from 2X4s and 3" screws
Dimensions:
2X4":
39 1/2" X6
42 1/2" X2
76" X2
Hardware:
3" screws ~X36
2-4" 200lb castors X2
plywood handle (or regular handle)
1-2" screws ~X10
Tools:
Miter saw
Screwdriver (cordless)
Step 2: Align and Secure
Start on a corner, and secure it, the long end overlapping the ends, with two screws on top of each other.
After one side is down, space the center 2X4s evenly, and screw in completely on one side.
Flip it on it's side and secure the other end, then secure the other side of the center 2X4s.
Step 3: Wheels
Adding wheels on one end allows easy movement to and fro the van.
Place on the corners, and trace the holes with a pencil or marker.
Drill pilot holes with a 1/8th bit, to prevent splits when screwing near the edges of the boards.
Fixed wheel style are cheaper and more secure than other, so that's what I went with.
Step 4: Stop and Handle
Adding a board at the opposite end of the wheels keeps the bed at an even level, making it more comfortable.
I used a trim gun to secure the stop board, so I could modify it easier later if need be.
A handle centered by the stop board turns the bed into a wheeling bed with easy handling
Step 5: Boards and Board
Normally, I would cut a piece of 4X8' plywood to fit between the mattress and the bed base, but I wanted to get it done quickly, so I used whatever scrap I had in my shop. It turned out quite well, even if it doesn't look amazing.
To insert the bed:
  1. Wheel it over to the trunk of your van
  2. Lift the wheels onto the back of the van
  3. Lift the handle on the other side and push
The stop board prevents it from rolling around in the back, even when driving like a maniac
Step 6: Bedding and Go!
When you have your van all spruced up (see glamping),
It's time to move your bed and get going!
Interested in more van hacks? See below!
Van Privacy Inserts
5 minute Van Divider
If you were inspired, or found it useful, please VOTE!!!!!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
