Wire Wrapped Tree of Life Tutorial
283,942
806
45
The symbolism of the tree of life is widespread throughout history, and is often depicted in religious, philosophical and mythological contexts. It also happens to be a popular jewelry accessory. There are many different versions of the tree of life pendant, and once you learn the basic steps you can easily add your own unique spin on it.
The finished examples shown use Baltic amber chips and peridot chips, respectively.
To make this tree of life pendant, you will need the following tools and supplies:
One 6.5" piece of 18g wire
Four ~6" pieces of 26g wire
3mm-5mm stone chips of your choice (2mm-3mm round beads also work well)
Flush cutters
Round nose pliers
Chain nose pliers
Cup burr or file
Round object
Supplies:
Step 1: Making the Circle
Take your piece of 18g wire and wrap it tightly around your round object. For this tree of life pendant, I'm using a cardboard tube that some hemp cord was packaged on - it creates a pendant slightly larger than a quarter when finished. Wooden dowels, metal mandrels and other scavenged household objects will also work.
Step 2: Starting the Pendant Bale
To create the pendant bale, use your chain nose pliers to bend one of the wires up at a 90 degree angle. Try to make the bend as close to the middle of the circle as you can.
Step 3: Making the Loop
Rotate the pendant around so that the bend you just created is facing you. Using your round nose pliers, create a loop with the piece of wire that you just bent.
Step 4: Finishing the Loop
Slide your circle over your round object again - this will help retain the shape of the circle as you work on finishing the loop for the bale. Using your chain nose pliers, wrap the bottom wire around once, and the top wire that formed the loop around twice. Cut the excess wire off with your flush cutters so that both ends meet at the back of the bale. File down the cut ends or use a cup burr to round them off so that there aren't any sharp wire ends on your finished pendant. Using your chain nose pliers again, firmly bend the filed ends down so that they aren't sticking up anymore.
Step 5: Step 5: Starting the Tree Roots
Take a piece of 26g wire and bend it in the middle. Place the bend that you just made on the bottom of your circle, and wrap the 26g wire around the 18g frame 3-4 times. You should have tightly coiled wraps when you're finished. Repeat this for the remaining pieces of 26g wire.
Step 6: Finishing the Roots and Making the Tree Trunk
Group all of your 26g wires together at the bottom of the circle frame. Determine how large you want the root system to be, and start twisting all of the wires together. Keep twisting until the tree trunk is at the desired length - the shorter you make the trunk, the fuller your tree will end up being.
Step 7: Separate the Wires to Start the Branches
Separate the 26g wires in pairs to make the tree branches. When you're finished separating them, you should have four branches in total.
Step 8: Twist the Branches
Now that the branches have been separated, start twisting each wire pair together. I usually make 5-8 twists. Once you're finished with this, you will end up with eight branches.
Step 9: Add Leaves to Your Branches
Starting with the first branch, add stone chips or beads to the 26g wire. Once you've added the beads to the branch, take the 26g wire and wrap it tightly around the 18g frame 3-4 times; don't cut off the excess wire yet. Repeat for each branch until all of them have leaves.
Step 10: Cut Off the Excess Wires
Once you're sure each branch is positioned the way that you want it, cut off the excess 26g wire. Don't forget to use your chain nose pliers to push the cut ends down against the 18g frame so that they are poking up anymore.
Step 11: Add the Finishing Touch to the Tree Roots (Optional)
Once I'm finished with the branches, I like to go back and bend the roots to give them a more natural look - feel free to leave them neat and straight if you like how that looks. Add your tree of life pendant to a cord of your choice and it's ready to wear!
Crafting Speed Challenge
Second Prize in the
32 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
  • Party Challenge
    Party Challenge
45 Discussions
JessikaN
1 year ago
Thank you so much for this great explanation!!!!! I´m making my very first "tree of life" :) I´ve seen many other tutorials before and never done it as tutorials were confusing,while you , divided it in few steps and demonstrated the technique in an easy concise way,
AmberC94
1 year ago
This is a great tutorial! I was able to make my very first Tree of Life pendant with your help. Thanks!
nlb333
3 years ago
I made this with a hula hoop. Im not sure about it. But ur tutorial helped
nancyjaneyoungnlb333
Reply 1 year ago
like the scale of the tree. I can picture it on a wall being embellished for celebrations in your home!!
Tbgelfling
2 years ago
There are SOOOO MANY loose ends to tuck and hide; it's really hard to get this to the point where it won't snag. I was wondering if you had any tips. I don't have bent flush cutters so I can't get a perfectly flush cut. Tips? Tricks? I know I need to get a metal file but I'm not there yet lol
nancyjaneyoungTbgelfling
Reply 1 year ago
Perhaps you can adapt....if you have stainless steel manicure scissors, they will easily cut and tighten lesser gauge wire. That is what used :)
nancyjaneyoung
1 year ago
Hello, Thank you for posting this excellent tutorial! I did not sign up for the lessons but I would be happy to do so! I used a key ring for the circle and heavier wire to make the tree. I did not add any embellishments because I will set the stone into a resin to for some aging adults as a comfort when they are alone.
BarbaraF63
2 years ago
Hello
Your trees are fantastic! Compliment!
. I like to
make a wire warped moonstone tree, but I don't know how to fix the flat stone
behind the tree...
Have a nice day, Barbara
Charchar1970
3 years ago
I just kinda went with what I had around the house..
Charchar1970
3 years ago
Love this so much!! Going to add more branches, and I think my frame wire is too big
photo-2016-04-19, 8:38 AM.jpg
ultimatecraftfan
3 years ago
This is really cool! I'm so going to try it, maybe with white beads for the Tree of Gondor...
Thanks for the guide! 18G silver frame with 20G copper branches. Peridot rough for leaves.
bkinbirmingham
4 years ago
A gift for my mom this Mother's Day. I am loving making these. Ty
15, 3:35 PM.jpg
MelanieD5
4 years ago on Introduction
Do you have a tutorial for that beautiful ring you're wearing?
carole.j.cann
4 years ago on Step 11
Just finished my 1st attempt of this . Excellent tutorial :) Pic to follow. Thank you
KadenL
This was one of the first wire projects I've done, so the first one didn't turnout particularly good but the second one came out perfectly! Makes a great gift.
