Wooden Texas Wall Decoration
2,399
57
6
About: I'm 16 in Waco, Texas. I love being outside and building things, I can build anything with just a few ideas and tools.
I really like rustic furniture and decorations and I love Texas. So I got the idea to make this when I saw a similar wooden wall decoration online. I have access to lots of flooring and I decided that this color of wood floor would work great. This type of decoration is pretty easy to make and really looks great when hung on the wall.
Step 1: Materials
-Wood Floor
-Wood Glue
-Strips of Wood
-1 1/4" Screws
-Wall Hanging Barckets
-Texas Map
Step 2: Glueing Planks Together
Begin by glueing together the tongue and groove planks. I ran glue along the inside of the groove and then hammered in the plank using a 2x4 as a rest. I would have really helped to use a clamp to hold the pieces together to insure they stay fully connected, but I didn't have a long clamp.
Step 3: Cutting Outline of Map
The template I used for this was a regular Texas map. Using an exacto knife I carefully cut around the outside of Texas to create my template. Remember the more exact you make the template, the better the product will turn out.
Step 4: Trace Outline of Map Onto Planks
Next, I aligned the template where I wanted it to go upside down on the back of the planks. I used small pieces of tape that wouldn't get in the way to hold it down to trace. After I finished tracing the outline, I removed the tape and filled in those areas.
Step 5: Cutting It Out
To cut out the outline of Texas I used a thicker blade for cutting out long straight lines, and a smaller thin blade for cutting tight angles. Also in some really tight spots I drilled a hole to allow better access. It took a while to cut out but don't rush, because this is the most important part and your detail will show.
Step 6: Mounting Braces and Brackets
I used some small strips of wood on the back of the planks to brace them together. The ones I used were 1x2s and the screws were 1 1/4in. I began by figuring out where they would fit best on the back. I then cut them out and sanded them to be smoother. I aligned them and screwed them down bracing the planks together. The hanging brackets I had didn't fit on the braces, so I had to add two more small pieces of wood to mount them. I should have used a different type of bracket but these were what I had.
Step 7: Sanding Edges
To smoothen to edges and give a better edge, I used 100 and 150 grit sandpaper to sand along the edges. It also removes sharp edges, burrs, and mistakes. It gave the edge a more overall uniform look.
Step 8: Hang It
Hanging it was a little bit difficult because it was such a weird shape and couldn't just level it. So I had to kind of guess, but I think it turned out perfectly centered. Once it was on the wall it turned out even better than I hoped it would. It gave just the right amount of projection to the wall. Hope you enjoyed. Thanks!
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    6 Discussions
    scottlangford
    2 years ago
    Where did you get size map at? All the ones I have have a huge Texas on them
    Cheese Queen
    4 years ago on Introduction
    Outstanding! Nice use of scavenged materials and a good rustic look. Of course, we Texans love decor using the Lone Star or the state, so a great job!
    seamster
    Very nicely done! My wife has been bugging me to make some state-based decor just like this. I love the way yours turned out!
    tomatoskins
    I love Texas! and I'm impressed with how level it looks! Good job!
