XHP70 High Power LED Flashlight - How to Make
850
9
About: There is no greater harm than that of time wasted - Michelangelo Buonarroti
How to make high power led flashlight with xhp70 led and big lens using old broken photo enlarger parts and old pc cooler. The lens is the main part of the build. Diy survival and hunting gear, cheap and simple to make.
Supplies:
Step 1: Parts:
12v XHP70 LED
Condenser Lens
XL4015 DC-DC converter
CPU Cooler
PVC Pipe
On/Off switch
Volt meter
14.8V 18650 battery pack
4s BMS
Step 2: Flashlight Body
Inside the photo enlarger you will find condenser lenses. Remove the lens and attach it to the pvc pipe fitting using silicone. Mine was a perfect fit, no silicone needed.
Cut a 30cm piece of pvc pipe. Make some holes for ventilation. Cut the holes for the on/off switch and volt meter.
Step 3: LED and Wiring
Make some holes in the pc cooler. Add some thermal paste and use screws to attach the led.
I draw a simple diagram, I hope you will understand the wiring
The led and cpu fan need 12v. I used xl4015 DC-DC buck converter to convert the 14.8 volt from the battery pack to 12v.
I used a 4s 14.8v 18650 battery pack with 4s Bms to power the flashlight.
The volt meter is used to check the battery voltage.
Step 4: Done
It is a very powerful flashlight, cheap and easy to make. It has the advantage of a large battery. Also it can be used for a long period of time because of the large cooler.
I hope it will help you!
Please comment if you have any question.
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Discussions
    Thank you! It is also also very efficient, now I am working on making them smaller(shorter) and light. I made a few for friends and family :)
