Forged Knife From a Railroad Spike
82,386
570
32
About: Teach me and I'll teach you
today I'll be showing you how to make a knife from a railroad spike. this has been done here before but I have a different process than the one I've seen that you can find here https://m.instructables.com/id/Forged-Railroad-Spike-Knife/ now you may have seen this way before but this other ible is the only one I could find here so I thought I'd show you how I do it have fun and be safe :-}
Supplies:
Step 1: Gather Your Materials
here's something things you should have
1. A forge (mine is an old hibachi style grill lined with refractory cement using a dollar store hair dryer as a bellow)
2. An anvil (I use a steel I beem and a slab of granite)
3. Hammers (I use a 3lb mini sledgehammer and a 16oz framing hammer for reasons unknown to me)
4. Tongs (I made mine)
5. Bench vice
6. Angle Grinder
7. 2 good size crescent wrenches (I only have one and a monkey wrench)
8. A handy dandy railroad spike
Now I assume you know proper safety procedures like gloves, eye protection etc so I take no responsibility if you cut burn pinch stub your toe or maim yourself in anyway :-}
let's get started shall we?
Step 2: Twist the Handle for Decoration
by now you should have everything set up and your forge going so what we're gonna do is heat up the half of the spike with the head.
Once it's red/orange hot take it to your bench vice and clamp the head and grab your wrenches and arrange them as shown in the second picture then give it as many twists as you like (I always do either a full rotation or a rotation and a half) but only do full and half rotations so as to keep the point in the direction it started in
Step 3: Draw Out the Tip
here you'll want to draw out tip of the spike for your blade do this by heating it and striking all four sides equally to keep it uniform.
get the tip as long and thin as you like this will require multiple heats in the forge
Step 4: Shaping the Blade
first hold the spike flat with the part you want to be the blades edge up and hammer the tip on an angle to give it a flat back.
Then strike the sides of to the blade to start your bevel the blade will start to curve towards the back if you want to straighten it simply work on the blades back to reverse this
Step 5: Bend the Handle
it should be looking like a knife by now but we're not done yet!
now here's where my I beem I have comes in handy you'll need to elevate the blade portion with the edge facing up as shown while the handle is heated give it a few whacks straight down to give it a little curve
Step 6: Grinding Time!
shown it the picture is my angle grinder locked in the bench vice a diy bench grinder
here you'll want to clean off all the scale and refine your blade and grind away anything you don't want
Step 7: Looking Good Almost Done
Ok now we're get close to the final product now what I do at this point is get my blade edge sharp but I don't polish anything because we need to heat treat the blade and temper it by heating it in the forge to a red/orange heat and quenching it in either water or oil after that toss it in the oven at around 350-400 for about an hour and let it cool
Step 8: Finish Up!
now you can clean and polish to your hearts content and sharpen that bad boy up
now that your done go show it off! :-}
notes:
1. sharpening and heat treating blades is not something I go into detail on because they could be viable ibles in their own right and I think a few are out there
2. where I live having these spikes isn't legal don't get in trouble
3. if you have any questions or suggestions feel free to ask or add them
4. thanks for reading :-}
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    32 Discussions
    PappaB1
    1 year ago
    I just built a coal brake drum forge last night....Err this morning. My neighbor has some spike and an piece of track. He has twenty hc spikes. Gonna play with some hot steel soon.
    ToddG18
    2 years ago
    I guess i'm a lucky guy since i grew up in an area where the old trains used to run back in the 1800's, possibly earlier. We've found old railroad spike all over the place. They are laying all around our barn back home. You can still go find some laying around. We always called it "the ditch" because it was a trench dug in the ground with berms on each side. One day my dad told us that the ditch is where the old train used to run through on the tracks. We've been finding spikes ever since.
    BaileyM3
    3 years ago on Introduction
    Where do you get your spikes? The only place I know where to get them is along my local tracks and I was hoping you'd know where to get newer ones, besides ebay
    Jake_MakesBaileyM3
    Reply 3 years ago
    As far as my experience goes, the older ones are better. All the newer ones I have found have an MC stamped on them, which means they are made of some other alloy, and aren't good for making knives. Why would you want newer ones? Is it because they have less rust? The spikes with less rust usually mean they have less carbon content, cause the higher the carbon content the more rust.
    smithy101BaileyM3
    Reply 3 years ago
    that's where I've found mine try looking for a place along the tracks where they've been working recently you may even find a small piece of track to use as an anvil
    ShanaL2smithy101
    Reply 3 years ago
    Can you email me I have a question for you
    hjjusa
    4 years ago on Introduction
    You do know that only railroad spikes with an HC on th head are suitable for knife making don't you?
    PaleHorseRiderhjjusa
    Reply 4 years ago on Introduction
    Are you aware that you can make a knife out of any railroad spike without having people try to correct you on what works.
    As long as you have it, you can forge with it. It's not illegal to forge a knife with an old railroad spike nor is it illegal to forge with any other solid piece of metal.
    You can destroy the US penny and other US made coins since you could have them for years, the government won't care what you do with it.
    So please, don't try to correct another user's project if it works for them & others.
    technically speaking it IS illegal to destroy coins, since they are federal property. but i agree with you
    Jake_MakesNickynui
    Reply 3 years ago
    No it isn't. If it is illegal, than most tourist attractions have been breaking the law for years with the penny flattening machines. And it isn't illegal anyway. If you read closely enough, you would realize that the law says it is illegal to modify coins for fraudulent purposes.
    ironsmiterhjjusa
    Reply 4 years ago
    Even the ones marked HC are considered extremely low carbon, by knife making standards.
    On the other side of things, knives have been nade of bone, rock, copper... even aluminium makes a servicable blade. High carbon steel just has the advantage of being tougher, and retaining an edge better thn most any other material, for general use.
    On a side note, I git a spike knife as a present. It stays sharp as well as some of my cheaper stainless pocket knives. If it is really important, go oldschool, and weld in a bit of tool steel for the blade edge.
    piperjonhjjusa
    Reply 4 years ago
    http://www.cartercrafts.com/carbon_myth.htm
    Interesting take on the HC railroad spike carbon composition, among other things.
    just curious. is there a way of knowing which is which? markings of any type? I have this and was thinking is doing something similar to this maybe a razor.
    smithy10140wolvesadancing
    Reply 3 years ago
    your spikes markings are either corroded or bashing in when it was installed but if you can see an HC stamp on them their considered High Carbon other marks if seen are HV and there's one more but I can't recall the mark those have a bit of copper in them
    moonchylde
    4 years ago
    I knew there was a reason I snagged a couple dozen of these spikes last summer (although I think it was mostly the "ooh, neat!" factor rather than any actual usefulness). Now I need to go back; I spotted several piles of spikes scattered around an old train yard, some three feet high (the piles, not the spikes). Now all I need is a forge...
    paul dito
    Excellent, back when the Embarcadero (San Francisco), was mostly train tracks my Dad and I would walk the dogs looking for spikes. I still have a few. Also, he made an anvil out of a chunk of track, now I just need to work on the forge...
    Thanks!
    smithy101paul dito
    Reply 4 years ago
    Thats awesome ive been looking for a piece of track myself for an anvil thanks for your comment :-}
    Awesome job my friend! I'll be making a forge sometime this month and forging a few of these myself & with a friend as well!
    Hope to see more projects from you in the future!
