Hat Side Camera Holder
5,811
48
9
About: I'm an Italian freelance structural engineer, graphic designer and photographer, and I'm teaching physics in Waldorf high-schools. I always investigate electronics, robotics and science in general, I'm a pas...
I've bought this veeery cheap camera made in china, and obviously it lacks an angular holder for my hat...
Luckily I'm a real genius, and after a long research and a lot of examinations, diagrams, computer simulations and testing I've came to the design of this high technological piece of engineering! With that gear I'm able to make my camera looking forward!! That's extraordinary!
... all right, I'm kidding, but because I'm not able to abandon a project halfway through, I'll go on ;-)
Supplies:
Step 1:
About the camera I can't say here that it's a pitiful piece of technology, so please ask me in pm... whoops!! Anyway I never expected GoPro abilities for 1/30 of its price...
Oddly as you can see I've two holders for the camera, but neither of the two can be mounted on the cap in the right direction. Except screwing the base of the bigger one on the cap peak... but I don't want it permanent.
Step 2:
So I decided to keep the clamp connector and holder, but change the angle between them.
To do that I've cut a piece of plastic frame about one and half inch long.
Step 3:
Dismantling the clamp you'll retrieve one bolt with nut, the second one comes from the other camera holder.
You can use a bit made for the electric screwdrivers, which is easy to keep in hand and to turn. Make tho holes about at the same distance from the borders.
Step 4:
Now screw the bolts and the nuts together, and glue them with some cyanoacrylate glue, so they'll not slack.
Step 5:
Now try the clip on the hat, and insert your camera on that. As you can see it will allow you to change the inclination both on longitudinal and traversal axes, so you can direct the camera forward.
Step 6:
Enjoy your excursions and rides, but much probably you can use it to film your instructables and diy works, because of the narrow field of view and lacking of stabilization.
I hope you had funny ;-)
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    9 Discussions
    manudel
    5 years ago
    Messaggi privati? Intendi dal sito web? Ho sempre usato l'app e qui non esiste la possibilità di inviare messaggi privati...
    so che non ha la possibilità di zoom W/L, ma la mia ha un problema di zoom ovvero è in zoom continuo. Infatti se riprendo un oggetto ad 1metro di distanza, nel filmato sembra che l'abbia ripreso a 50cm di distanza... Inoltre se dovessi riprendere il paesaggio dalla mia finestra, sarebbe tutto sfocato... Cioè è utile solo per unboxing and how-to.
    Comunque si hai ragione! Per quel prezzo è già tanto ahaha
    Ne ho comprata un altra simile ad un telecomando per cancelli e avrei bisogno di un tuo consiglio per creare un sostegno per poterla montare su un casco...
    andrea biffimanudel
    Reply 5 years ago on Introduction
    strano per i PM... strano anche il problema di zoom e di sfocatura... non saprei aiutarti. Per l'attacco potresti postare un'immagine nel forum oppure contattami su: mail[at]andreabiffi.com
    manudel
    5 years ago
    Hey Andrea prima di tutto complimenti per i tuoi instructables! ;) sei il mio instructabler preferito!! Continua cosi!!
    Volevo chiederti solo una cosa: la videocamera ha un problema di zoom vero? Ne ho una anche io... Come posso contattarti senza disturbarti per parlarne? Graxie
    andrea biffimanudel
    Reply 5 years ago
    Ciao manudel, che io sappia quella videocamera non ha lo zoom... ma a quel prezzo non si può pretendere troppo... comunque le riprese in movimento sono pessime. Contattami pure con i messaggi privati di instructables. Bye
    manudel
    5 years ago
    *grazie
    msel
    6 years ago on Introduction
    I bought same camera from aliexpress but it disordered :/
