How to Sugar-wax Your Legs
554,694
515
219
So, it's winter. If you live in the buttcrack of Minnesota like me, around this time of year you look at your legs and go, EW! I REALLY LOOK LIKE A YETI! This instructable is an easy way to wax your legs at home with stuff you have in the kitchen. after the first few comments I have recieved I feel compelled to expound upon this instructable with some history and reasons for waxing. Ok, waxing is an alternative to shaving and has pros and cons just like shaving. The pros are that waxed hair grows back slower,softer and lighter than shaved hair, especially if you have been waxing for a while. The major con is that it stings a bit. But come on, it's really not that bad. Also, this method of waxing with sugar has been popular since antiquity. My family is from Israel and sugarwaxing is called "Hawala" in the Middle East, where it originated. Some guys that have commented seem to think this is gross (or maybe it's just my hairy legs in the pic). Dudes- ask your girlfriend (or your mom) about waxing. It's very common and pretty spendy at your local salon.
Supplies:
Step 1: Stir It Up
you will need-
- 1 cup sugar
- 2 TBSP water
- 2 TBSP lemon juice
- small sauce pan
- butter knife or popsicle stick
- several cotton or linen fabric scraps cut into 3x5in. strips (old sheets and dishcloths work great)
- hairy legs ( at least 1/2 inch of growth)
Add the sugar, water and lemon juice to pan and bring to boil over medium heatand boil over medium-low heat for 5-8 minutes stirring CONSTANTLY(!) the mixture should be slightly frothy but not boiling up all over-adjust heat accordingly. The mixture is finished when you can look at a spoonful of it and see no granules of sugar.
Step 2: Cool It
let the mixture sit in the pot for a few minutes ( until it is the consistancy of honey) then pour it into a heat-safe container.
Step 3: Is It Ready Yet?
stick the stuff in the fridge for a good 15-20 minutes. when it has cooled to the point where it is lukewarm, you're ready to de-hair! PLEASE make sure that the sugar wax has cooled enough because you can really burn the crap out of yourself if it is too hot (super-hot+super-sticky=napalm!!!!)
Step 4: Rip It!
ok, now bust out those hairy legs and spread a thin layer of sugarwax on a small part of your leg use butter knife or popsicle stick. Immediately cover that area with a cloth strip and rub it down firmly. Now close your eyes and think of a happy place and quickly tear the cloth strip away from your leg in the opposite direction of the hair growth. Swear loudly and repeat this process until your legs are as smooth as Ella Fitzgerald's voice. You can save any leftover sugarwax in the fridge and microwave it for use again, although I have no idea whether it would go bad after a while or not.
  • Gardening Contest
    Gardening Contest
  • Arduino Contest 2019
  • Woodworking Contest
    Woodworking Contest
219 Discussions
MoochC
1 year ago
I've made my own sugar wax before and even though it works ok and is relatively cheap to make, it's certainly not worth the time to make or the clean-up involved afterwards when for about $8 you can buy a premade sugar wax ,which usually gives you several wax treatments, at the beauty supply store .
KaitlynA1
3 years ago
Ok i need help really bad i did everthing it told,me and i let it cool for a while. But still,really hot and if i let it cool,anymore it will,be hard as a rock so what do i do ???!?!?!?
MoochCKaitlynA1
Reply 1 year ago
You overcooked it to the hard-ball stage, there's nothing you can do. You're working with sugar and it's just like making candy so you have to stay within certain temperature ranges to achieve the desired consistency or you're going to end up with something that has the rock hard consistency of a sucker; usually 225 to 230 degrees is high enough of a temperature to cook the sugar "wax" to. Next time place a small drop of the cooked syrup in cold water. If the product slightly retains it shape but is still very soft when removed from the water it's cooked enough. Better yet just buy some hair removal wax at the beauty supply. I've made my own before and it's not worth the time or clean up to make something I can pick up at the store for around $8 which I can use several times.
prickly vegan
2 years ago
Just a tip, from what I've read, the direction of application and ripping matters quite a lot. According to several online sources, it is most beneficial to apply the wax in the opposite direction of hair growth, then pull off the strip/wax in the direction of growth. This helps to prevent ingrown hairs, and might be less painful. Worth a try anyway. Also, I find it less painful when doing small patches at a time. When you start running out of patience, you'll be happy to suffer more by doing larger patches. ;) And, no, I have no idea why people think this is gross. It's just hair, people!
MoochCprickly vegan
Reply 1 year ago
Hard wax is pulled in the direction of hair growth while sugar/honey waxes are pulled in opposite direction of hair growth. The only way to prevent ingrown hairs is to exfoliate waxed area frequently during hair regrowth.
AniketD17
2 years ago
it burns everything turns black.sucks.!
VivianneL
3 years ago
SOOOOOO GROOOOOOSSSSSSS!!!!!!!!!!????????
ElizabethG38
3 years ago
https://youtu.be/WoS1uuddqcM
NightRain1
3 years ago
For all those like me who had a hard time with this (it got hard and not sticky) i discovered the reason. We probably burned it. So don't cook it quite so long next time and it should work
EricB12
3 years ago on Introduction
I did this just a week ago for my wife and it worked perfectly. You would be surprised how easy it is to make some common household products we use on a daily basis. The lotion you use has a main ingredient that is aloe vera. You can grow it in your home and use it as a lotion, or to remedy burns and cuts. This article was a quite a great and informative read.
Eric | http://www.letsfaceitcharlestown.com.au/beauty-treatment/waxing
EricB12
Mortem_Deus
4 years ago on Introduction
I made this mixture and put it on my hairy legs.
I must of done it wrong as it felt like tearing my own skin off.
I now have a small patch of very red skin and I must say I am close to tears.
2/10 would not do again.
P.s I'm a male ;-;
KaitlynA1JuliaR3
Reply 3 years ago
Well i did everthing that it told,me to and it burns my skin and like,its really hot i let ir cool down but it gets hard so what do i do
lilowloffeathers
4 years ago
Plesse for the love of god, do NOT put the hot/warm mixture in the fridge, heated foods and drinks can cause your other fridge contents to go off and mouldy.
I would simply leave the mixture out on the side to cool, next to an open window preferably with a cloth or tea towel covering the bowl so that no dirt or bugs get stuck in the goop.
This stuff works awesome!Just finished one leg, about to move on to the other. Scared to try my unmentionables but I think i will brave it out later and try it out...Wish me luck!
jianqiang
10 years ago on Introduction
I'm assuming doing this waxing thing is kinda a no no(or for the brave?) for unmentionable areas...or is it?
