Multi Key Utility-Key 10+8-in-1 Tool (may Expand)
98,298
345
67
Multi key Utility-Key 10-in-1 Tool
Material: Ni+Fe (nickel-iron)
Weight: 6gr ~1/6 oz.
Length: 5,6 centimeters = 2,20472441 inch
With: 2,5 centimeters = 0,984251969 inch
Thickness: 0,2 centimeters = 0,0787401575 inch
1. drill (better efficiency than Phillips screwdriver)
2. saw (wood)
3. bottle opener (beer)
4. rope cutter (nylon, cotton ....)
5. screwdriver
6. hexagonal key (exp: Phillips screwdriver plug-ins)
7. knife sharpener
8. wire cutter (copper, paperclip)
9. nail
10. nail file
11. magnetic (old Winchester magnet over pull up)
12. can opener (not elegant) 1st saw tooth
13. polished back -> signaling mirror
14. fluorescent light from Lego Bionicle pieces (drill 2 mm hole, injected fluorescent material) cool!!!
15. knife
16. ruler ( front, upper saw empty area "cm" measure ~2,5 cm)
17. the head of key is trolley coin, after you open it, removable
18. Phillips screwdriver lite (pc cover disassemble) between 5-6 area !!! photo is coming
coming soon ..... ++
plans for the future:
-must have bigger, and stronger key!!!
- Directional instruction:make use of accurate determination of sixteen equal portions of the scale different range.
- sun-dial (need: horizontal surface ,Which direction is north)?
- compass(key is magnetic -->water , leave,or paper etc swim done, /work well in theory?/) need a test!
- glass cutting wheel(Alloy, or industrial diamond, or park plug porcelain) between 9-10 area,[solder?
glue?]
Supplies:
Metal Challenge
Finalist in the
Metal Challenge
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
67 Discussions
VitizopGold Leader
Reply 6 months ago
cable string rope letter cardboard box nylon....etc..
light things...
dewanm
4 years ago on Introduction
its awesome bt making tutorial would be nyce cozz with some curves i need some helps and informaion
dewanm
Qwertyfish
4 years ago
If I wanted to make one out of a key blank how would I harden it?
jware4
5 years ago
WHERE CAN I GET ONE?!?!?!!!!!!!
cut those valleys down to 999 and you can also use it to bump pick some locks. you may have mentioned that, but I didnt read all the way through. Awesome instructable, though!
keng
6 years ago on Introduction
you don't need a battery per se...it's solar...well, with an easy mod anyway.
GcamperDatawolf
Reply 6 years ago on Introduction
What battery? Do you realize that bottle openers, can openers, and saws are not electric?
subrotosBrian H
Any way of using rechargeable cells here? Or would the "memory effect" of NiCADs get in the way?
Totally agree,you could be saving lives with this thing.Strongly recommend
you send it to the army.
